RCA 52 LCD Model #D52w17
I think we may have 2 problems but not sure. 1. We have to unplug the TV every night in order for it to come back on the next day. 2. Noticed that the color on left side of screen is not normal- example shows yellow on shoulder of someone wearing a white jacket.
  • lilhonie43 Apr 13, 2008
    It was pushed from 1 room to the other but it has been in the same room for over a yr. TV is about 5yrs old.
    Sergeant:
    Champion:
  • 375 Answers
Sounds like the set took a drop at some time and both errors are related,service shop maybe required.
Posted on Apr 13, 2008
I have a 52" rca model D52W17. I turn it on and about 10-15 minutes later it just cuts off. Sometimes it trys to cut back on and then goes right back off. I smell nothing burning, screen looks fine when on...
without takeing mesurment i would be makeing a guess = there are some capacitors that could be going bad.. intermetant or delayed shutdown ussally means a overheating or failing component or bad solder connections.
Oct 13, 2010 | RCA HD52W56 52" Rear Projection HDTV
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W17 wont come on, the green power light goes on and off three times then stays off.
On deflection board CK capacitor cp 150 2200uf 16v use 25v if i is puffed up on top it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v for parts call Mats 1-800-628-1118
Nov 12, 2009 | RCA D52W19 52" Rear Projection Television
37"RCA Lcd TV quit working
no parts available google model for part # for main pcb
Jun 08, 2009 | RCA L37WD12 37 in. LCD HDTV
Tv wont turn on
try replacing the flyback 259296 and CP150 both items are available at the following link with free instructions.
http://servicemanuals.vstore.ca/
Dec 20, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
RCA MODEK D52W17 Cant Get Any Remotes To Work This TV
The remote receiver in the TV is failed. It is possible that a TV repair shop might be able to fix the problem for you
Jun 18, 2008 | RCA HD52W58 52" TV
RCA D52W17 won't stay on.
Possiblility include bad convergence cuircit. A component that is overheating and bad solder connections.. Technicians can use special equipment to read error codes... this will tell them the error that is shutting it down
Mar 13, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
