Question about Bosch Washing Machines
My Bosch Nexxt Essence front load washer is making a knocking and squeaking noise during the whole spin cycle. It sounds like it's coming from the drum mounts - what should we do?
    New Friend:
What it is is the drive belt on big pulley needs a lube, that squeking noise will go away, the belt gets dry and tension of a dry belt makes that noise i confirmed it on my bosch washer.
Posted on Apr 16, 2016
My Bosch Nexxt Essence front load washer will not drain. I changed the lint filter, and insured that the drainage hose was free of debris. I removed all the wet clothes, wrung out the excess water, and redistributed the clothes. Still, no draining or spinning. Initially there was a humming sound, but now there is no sound at all when I try to restart the drain or spin cycles. All the lights are appropriately "on".
Posted on May 24, 2008
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
When the dryer is running it sometimes makes a screeching sound momentarily on and off during the dryer cycle. Some cycles it does not make the sound at all. Is something going bad? It doesn't seem to...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
May 02, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak noticed on floor right in front after wash cycle is completed. This occurs every time I use the washer.
Bosch Nexxt Essence WFMC 2100 UC (washing machine) Water leak This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 26, 2010 | Bosch WFMC2100UC Nexxt Essence Washer
Nexxt Washer Problem
timer not sending signal, or bad transmission
May 08, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
During the washing cycle there is a noise that sounds like something is "clicking" inside ( kind like washing something made of metal inside the drum). it is steady and lasts through the whole washing...
I would suspect that something is caught between the inner and outer drum, like a bra wire or something similar.
If it washes and spins o/k, then I don't think it is a fault with the washer.
It will probably break up, or find it's way into the pump filter.
Hope this helps.
Jan 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
845 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
