FixYa.com
Tags:
Intel Diamond S3 Trio 64V+,  Graphic Card
Game controller configuration problem
By Chandler - usenet poster
I am having a problem with my game configuration program in control
panel.When I try to configure my controller the crosshair (+) that shows for
center position jumps and bounces.Everything configures but whan I play a
game with it whatever is controlled by the d pad jumps around making it very
difficult to make my selections.I have not found a fix for this problem
anywhere on the net.I had another contoller and had the same problem.I
thought it was that particular controller but it does the same thing with my
new one.
If anyone knows what the problem is or has any suggestions I would greatly
appreciate it.
Thanks alot
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 10, 2005
Thanks for Trying (70)
Bray
Bray - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On Thu, 12 Apr 2001 00:26:18 GMT, "S.Cook" <jshc @earthlink.net>
wrote:
Not enough info.
Post full hardware specs and what you have plugged in where :O)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
On Thu, 12 Apr 2001 09:48:41 GMT, "S.Cook" <jshc @earthlink.net>
wrote:
<snip>
Boot to Safemode and in the Control Panel remove all controllers and
also if there is ant software installed for the old device remove
that.
Then whilst still in Safemode go into the Device Manager and remove
ALL gaming devices and the human interface devices and re--boot.
Back up the registry 1st,free WRP program off here,
http://www.d-sheppard.f2s.com/ free.htm
And or know about the scanreg/restore option to reset the system after
system changes,
If a problem is less than 5 days old in win98 then restart F8
bootup/Command prompt only Dos or restart in Msdos mode and type
scanreg/restore and try an older reg backup,however you may have to
re-install some programs  and user changes if they were installed
after this date.You can type win or exit from Msdos mode to get back
to windows.
HTH*<:)
Solution #3
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
Below are my system specs.The controller in question is a Gravis Gamepad Pro
and it plugs into the USB port.
The other gamepad I had was an Interact MakoPad and it plugged into the
standard gameport.Both act the same in configuration
System Scan v5.1
Copyright 1998, Westwood Pacific
Software created and developed by Brian A. Fliege
***BEGIN_DATA***
V:5
CPU:Pentium Pro
MT:IBM PC/AT
BN:RegistryScan does not know
BV:PhoenixBIOS 4.0 Release 6.0
BD:08/27/98
M:65148 k
CDROM
 EPO CR-850S
  MFG:(Standard CD-ROM device)
  HWREV:
DiskDrive
 GENERIC IDE  DISK TYPE01
  MFG:(Standard disk drives)
  HWREV:
 GENERIC NEC  FLOPPY DISK
  HWREV:
Display
 ATI 3D Rage Pro (atir3)
  MFG:ATI Technologies
  HWREV:092
fdc
 Standard Floppy Disk Controller
  MFG:(Standard floppy disk controllers)
  HWREV:
hdc
 Intel 82371AB/EB PCI Bus Master IDE Controller
  MFG:Intel
  HWREV:001
 Primary IDE controller (dual fifo)
  MFG:(Standard hard disk drivers)
  HWREV:
 Secondary IDE controller (dual fifo)
  HWREV:
HID
 USB Human Interface Device
  MFG:(Standard device)
  HWREV:
 ixla Digital SuperPro 640 Digital Camera
  MFG:IXLA Limited
  HWREV:
Keyboard
 Standard 101/102-Key or Microsoft Natural Keyboard
  MFG:(Standard keyboards)
  HWREV:
MEDIA
 Creative Sound Blaster AudioPCI 64V
  MFG:Creative
  HWREV:002
 Gameport Joystick
  MFG:Microsoft
  HWREV:
 HID-compliant game controller
  MFG:(Standard game device)
  HWREV:
 Microsoft Streaming Clock Proxy
  MFG:Microsoft
  HWREV:
 Microsoft Streaming Service Proxy
  MFG:Microsoft
  HWREV:
 Microsoft Streaming Tee/Sink-to-Sink Converter
  MFG:Microsoft
  HWREV:
 SB AudioPCI 64V Legacy Device
  MFG:Creative
  HWREV:
Monitor
 (Unknown Monitor)
  MFG:(Standard monitor types)
  HWREV:
 Plug and Play Monitor
  HWREV:
Mouse
 PS/2 Compatible Mouse Port
  MFG:(Standard mouse types)
  HWREV:
Net
 Dial-Up Adapter
  MFG:Microsoft
  HWREV:
NetClient
 Client for Microsoft Networks
  MFG:Microsoft
  HWREV:
 Microsoft Family Logon
  MFG:Microsoft
  HWREV:
NetTrans
 TCP/IP
  MFG:Microsoft
  HWREV:
Ports
 Communications Port (COM1)
  MFG:(Standard port types)
  HWREV:
 Printer Port (LPT1)
  HWREV:
PRINTER
 Hewlett-Packard DeskJet 610C
  MFG:
  HWREV:
System
 Advanced Power Management support
  MFG:(Standard system devices)
  HWREV:
 Direct memory access controller
  HWREV:
 Intel 82371EB PCI to ISA bridge (ISA mode)
  MFG:Intel
  HWREV:002
 Intel 82371EB Power Management Controller
  MFG:Intel
  HWREV:002
 Intel 8
Solution #4
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
wrote:
Its a common problem with analogue joysticks, I have an analogue
joystick and does exactly the same thing. In some games such as Final
Fantasy it makes character control impossible as the characters are
twitching like as if they've gone mental! I had to remove the joystick
to play it.
I think the best solution is to switch to  USB joysticks which do not
suffer from twitching...
Peter Hutchison
http://www.blizzard.u-net.com/ winhelp.html
Can you Help with these Graphics Cards problems?
Graphics Cards
epson c90
i had my epson c 90 for about 6... Answer This...
Graphics Cards
capture device on videocard...
I bought a videocard MSI... Answer This...
Graphics Cards
station9ld back again
lost internet connection, will... Answer This...
Graphics Cards
Video Card
I need some help about my... Answer This...
Graphics Cards
Runescape on line game
Runescape have upgraded there... Answer This...
Repair Service
Find Graphics Card Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
