Question about Sony SLV-D350P DVD Player/VCR
Vcr I am having trouble playing back the recording on our vcr. How do you do it? Thanks!
Check if the connections at the back panel. maybe the connection from the source going to the input of the vcr is not properly connected. if there are more questions email me. dfbrodriguez@yahoo.com
Posted on Apr 13, 2008
My Sony RDR-VX530 VCR/DVD player/recorder just stops playing
play a lens cleaner cd in it,,, it will work smoothly
Apr 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Magnavox dvd recorder/vcr
It sounds like you may have your vcr connected via composite cable. Check the back of your VCR and follow the cable to your TV. You should see a Red, White and Yellow connection on both ends. The Yellow connector is the video.
Here is an image to help you find it:
Feb 18, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
Hi. My VCR will not record or play on channel 3 only channel 4. It was recording/playing on 3 . How do I get it back. Thanks Chris
Hi chris If you mean that the tv has to be on channel 4 instead of 3 then look at the back of your vcr , there is a swich to select the output channels 3/4.
Hope this help
Dec 02, 2009 | Sharp VC-A560U VHS VCR
VCR will play, but won't record
Your VCR has to be on the same channel as the switch on the back of you cable box.
Mar 05, 2009 | RCA VR557 VHS VCR
How can I record TV show? What buttons do I push?
Well my friend, you have many variables that can cause this issue. Here is a list.
  1. Check the tape record prevention tab to see if it is not missing that will cause it NOT to let you record. Put a piece of scotch tape over it if you wish to use that tape.
  2. Make sure it plays back. If it does not play back, it might not record.
  3. Turn the TV on, look for Audio and "Video Out" and connect it to the INPUT Video Out and Audio Out. You cannot use the TV to power the VCR. The power plug must be connected to the wall outlet.
One of these should solve your issue.
E
Mar 02, 2009 | GE Televison & Video
VCR won't record
Check to make sure the cables on the VCR are hooked up correctly. If the in and out are reversed, this might cause your problem. Hopefully it's as simple as that. if not leave a comment and I'll get back to you.
Oct 03, 2008 | Quasar VHQ400 VHS VCR
VCR SLP playback problem
I would first have it cleaned.
Jan 29, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Problem with programmed recordings
DID you set the channel on the VCR to the sttating your recording? Also does your cable go to the tv, then to the vcr? If so the channel you record will be the one your watching. Or did you accidently screw the cable into the "cable out" on the dvr?
Nov 27, 2007 | Rio DVR4100 DVD Player/VCR
Audio
Does it play back professionally prerecorded tapes okay? Does that VCR have a HiFi stereo option? What is the brand name and model number of the unit?
Apr 24, 2017 | Panasonic PV-C1331W 13 in. TV/VCR Combo
Sony SLV-D350P DVD Player/VCR Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
