To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
ou can save up to 8 phone numbers in your speed dial book. The speed dial keys go from 2 to 9. When you place a call, our system prompts you to "enter the phone number you wish to dial". You just press the appropriate speed dial key followed by the pound sign (#) and your call goes through. No long numbers to enter any more!
If you set a speed dial for our access number on your phone machine, you have to press three keys only to complete a dial - as easy as "1-2#"! That's it!
For example, you can set your parents' phone number as speed dial key 2 and your friend's number as key 3. After dialing the access number from your phone, you will press 2 then # to reach your parents, or press 3# to reach your friend. Nothing could be easier! Speed Dial set up Instructions: Dial the access number, wait for prompt. Enter PIN number, wait for prompt. Dial: "#" "2" "#" [a speed dial number: 1-9] "#" [destination number] "#". The system will confirm the number. Example: [#] [2] [#] [5] [#] [011-888-88-88-88-88] [#] Use Speed Dial: Dial the access number, wait for prompt. Enter PIN number, wait for prompt. Dial: [speed dial key (1-9)] "#" Hope this will help to solve the problem....
if you already have contacts in your phone book and you have follow the set up info given...its just like retrieving your voice mail you normally would press the number "1" key...lets give it a test run press the number 5 key down for a second or two and release...it should be dialing whoever is in the the #5 spot...you just place your first speed dial....try it again lets call that number 9 ...note you can always change the positions (callers) in your speed dial..just simply go to the phone book to who you want to replace (eg.you want replace Debbie #4, go to Sam... options/speed dial/ #4 this will over ride who is in that position)
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows: [most of this from Phonebook/More/Settings/1 ]
1. Copy all address book entries from Sim to Phone Memory. 2. Delete all Sim Address book entries. 3. Switch Address book source to Sim. 3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial. 4. Switch Address book source back to Phone Memory.
From now on all numbers on the Sim will be in Speed Dial and you will view the address book from phone memory. Of course any number can be in both places.
Now to speed dial just enter 1#, 2# etc for any number in the Sim Address book. You will get to view and confirm the entry and then dial. In a way this is even better then the speed dial functions on older Samsungs, as the preview before dialing ensures you have the right speed dial entry.
I think it works fine. dk
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device. To manually create a speed dial entry
In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings.
Click New Entry.
In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK.
In the Speed Dial Settings dialog box, click Save.The entry is stored on the HP device. Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again.To create a speed dial entry from the Address Book
Under Address Book, click Select From.
In the Address Book dialog box, select one or more names, and then click OK.
Follow the following: >Call Center at the bottom >General call settings >03 Speed dial >Check that "enable speed dial" is on Then >02 Set number >You will see a list of "empty" >Touch on the one you want to assign a number >Edit >this takes you to your phone book >Choose a name from your list and save it to your speed dial. >To
call the number from your speed dial list, click on the "Phone dial"
icon, and hold the number down. For example, is the number 2 is home,
hold 2 down until you see it dial and there you have it.
Hopes this helps
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows: 1. Copy all address book entries from Sim to Phone Memory. 2. Delete all Sim Address book entries. 3. Switch Address book source to Sim. 3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial. 4. Switch Address book source back to Phone Memory.
To assign a number to a speed dialing key, select Menu > Address Book > Speed dial list, and scroll to the speed-dialing number that you want. Select Assign or, if a number has already been assigned to the key, select Options > Change. Select Find and the contact you want to assign. If the Speed dialing function is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number in either of the following ways: • Press a speed dialing key, then the call key. • If Speed dialing is set to On, press and hold a speed-dialing key until the cal
