Question about Arris Touchstone 450a (CM450) Modem
I spilled water on the floor, and it went under my modem so i tried to dry it up. after i dried it up, the power button was blinking so then i plugged out the power plug for the router, and now it doesnt blink at all any suggestions on how to fix this ?
My Acer Chromebook wont turn on after a water spill
Power IC maybe damaged by water, try opening the whole system and dry the circuits and body and reassemble and try again, and well last option is always service center..
Mar 19, 2015 | Acer C720 11.6" Chromebook - 2GB Memory -...
Water got into my Xbox 360 by the fan can I fix it
Let it dry out give it a day or two before plugging it in put it in front of a fan or heater to dry out good. Was the Xbox plugged in when it got the water on it? Once its dryed out you can try plugging it in.If it doesn't power up you probably fried the power supply. But if it was like a glass of water got spilled and some splashed near fan it probably will work. I think there are even some fuses in side the Xbox but you should leave that to a professional. If it doesn't come on once its dryed out
Apr 11, 2012 | Microsoft Video Game Consoles & Games
Nasty molding musty smell...started iout of the blue. It is now early spring have not used A/C yet. It is making me sick
Musty smell comes from three possible situations.
First is simply a spilled liquid on the carpet. A thorough carpet cleaning will get this.
Second, water entering the body of the car. (IE: leaking door seals , window seals, or the hardest to find... coming in under the carpet from the floor pan) Barring leaks from the seals and spills, The floor pan has drain holes and rubber plugs that may dry out and allow water from below the car to enter.
Third, Your A/C unit is developing this condensation in the Air flow Box (complicated air flow box under dash holding your heater core and A/C core) This is a common problem, but requires a de-mold solution best applied by a Pro. You can buy over the counter solutions (sprays) and then make sure you run the heater after each A/C run. That works for many as it dries out the condensation the A/C produces.
Hope this helps.
Apr 14, 2011 | 2002 Volkswagen Passat
I spilled some water on my royal cash register, and it was beeping and giving me a error sign. I unplugged it and turned it upside down to try and get the water out. Can I fix it without buying a new one....
You should immediately try to dry the membrane inside the keyboard. You normally need to unscrew many screws in the back of the keyboard to get at it. it will be plastic sheets with little black tracks on them. Dry them gently with LOW heat or wipe until dry. also look for any water on the main circuit board and dry with gentle fan for few hours
Feb 28, 2011 | Casio Parts Cash Register PC Desktop
My clean light is blinking and it will not start
Push in this order within 5 seconds...
Sani Rinse Air Dry Sani Rinse Air Dry....if you dont have those buttons, substitute:
Hi Temp Wash Heated Dry Hi Temp Wash Heated Dry
Let it go through the diagnostics cycle, about 10 minutes. Push Cancel/Drain. If it occurs again, you have something wrong with the heater circuit. Check the heating element for breaks.
Jan 13, 2011 | Kenmore Dishwashers
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
My daughters's calculator got wet when something spilled in her book bag. We took out the batteries and let it dry out. Later we put in new batteries and it works but is extremely slow and I have to press...
If water was spilled in it, the batteries should have been removed immediately, if you could remove the circuit board from the casing, dry it off and place it under a lamp for a few hours it should have been perfectly fine. If a soft drink, sugar base or other substance was spilled in it; the board would need to be cleaned, a small amount of soap and water can work, use a cotton swab, only clean the affected area of the spill, make sure to rinse all the soap off, dry with towel, then place under a lamp to get all the moisture out. Also make sure you clean the bottom side of the buttons that contact the circuit board. If it doesn't work then you may have to buy another unit.
Jun 19, 2010 | Texas Instruments TI84Plus Graphic...
Water spilled into my laptop Dell Latitude D600. what do i do
  1. Disconnect any power and remove the battery
  2. Tilt the system in various angles to drain as much of the water from the system as possible.
  3. Let the system dry for several days, (I'd say a minimum of 4) is a relatively warm place
  4. Insert Battery, see if system will power on.
If the system was powered on when the spill occurred and turned off by itself during the spill, then the motherboard has most likely been damaged and will need replacement. ($100 or so on EBay)
If the system will not power on after drying, you might consider replacement rather than repair as the cost of fixing it could exceed the replacement cost. (Dell has portables starting around $399)
http://www.dell.com/us/en/home/notebooks/laptop-inspiron-1545/pd.aspx?refid=laptop-inspiron-1545&s=dhs&cs=19
Dec 24, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
Spilled diet coke on laptop. Buttons light up but the screen remains black.
Disconnect your battery and neveeeer turn it on. It must be, no power is connected to it. Then bring your unit to a authorized repairer.
They will clean it and have it dry, check others. This will gonna involved disassembling the unit.
May 31, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
White screen on samsung sch-r450 messenger frm water damage
the only possible thing you could do yourself is to remove the screws, pull it apart and try to blow dry. That's the only thing you can personally do.
Apr 21, 2009 | Samsung Cell Phones
Arris Touchstone 450a (CM450) Modem Logo
457 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
