Question about Franke WD751B GPS Receiver
Franke Little Butler instant hot water dispenser
Unit is 2 years old. Never any trouble. Tonight water (not hot) is leaking from the bottom of the housing unit. Unit dispenses hot water from tap ok.
  • 4 more comments
  • leonardjan Aug 06, 2008
    Same thing - just pulled it apart - the tube inside had disconnected and water was going into bottom of unit as well as into the water hose. Still trying to figure out how to replace broken part and replace.
  • mariogo Dec 08, 2008
    rubber tube has failed twice and I cannot find a replacement. Suggestions?
  • laneuro Jan 07, 2009
    We have two heaters, and they all have the same problem. Why do they design the unit this way. Don't they know that the Norprene Tube will crack with high temperature? I wish someone comes up a replacement. this tube should be copper, not Norprene.
  • ccmagichands Jan 22, 2009
    I have the same problem. The hot water hose from the heater to the valve blew out. The hot/cold filtered water valve was my second. The original had copper lines but the valves went bad. As soon as I got the replacement and saw the rubber (flimsy) hose I knew it would not last. At the time I could not find anyone else that made a brass valve that did hot and cold and worked with the little butler hot water tank. I made a fitting that could screw onto the bottom threaded fitting where the hose goes into was going to use copper pipe instead but you would have to be able to drill and tap a 3/8 pipe fitting and it would have to be drilled to tap a 12 mm x 1.5 thread which is not a pipe thread. I was going to use a lot of teflon tape which should work but found that the ridiculous rubber hose goes up inside the spigot and it will not pull out. I attempted to take the spigot apart but have not succeeded yet. Can not figure how to get the end of the spigot off without damaging the brass.
  • DeborahSue Apr 30, 2009
    There is a valve at the bottom of the hot water heating unit - it is leaking and causes air to build in the unit so that when you turn the valve for hot water you get air until the unit primes and then you will get hot. The bottom of my cabinet is soaked! How can you fix this?
  • Kevin Aug 11, 2013
    Good advice. Mine leaked, but simply reattaching the rubber hot water out tubing to the top again using the ratcheting hose clamp did the trick. Thanks!
I have the same unit and had a similar problem. If yours is the same as mine, look at the top of the water heater unit. The center spigot is for the for the how water outflow which is connected to surgical type rubber tubing. The hot water eventually dried out the tubing and it cracks, causing it to leak. I had to cut out the decayed portion and replace it. Franke sent me a replacement kit at no charge but I did replace the fitting on top of the unit. The fitting is a standard nipple that any HW store should carry. Mine is a female-to-female reducer that then mates to a nylon barbed fitting which the tubing goes into. Importantly the Franke supplied kit has nylon ratcheting hose clamps that keep the tubing in place as well as a barbed union with hose clamps to join to the exisiting hose feed (to the faucet).
Hope this helps! I'm now struggling with the hot water tap leaking after using it. It seems to stop after a while but it drips for some time. If you can help me there that would be great!
Posted on Nov 22, 2008
Hi, I found that the water keeps dripping out after use if the temperature is turned up to the maximum. Maybe it's boing too high or creating steam. If I turn the temp down a little, no more dripping.
Posted on May 22, 2009
LB2280 leak
If this is instant heat faucet, then contact manufacturer.
Most these faucets have 1 year limited warranty
Replace faucet?
http://waterheatertimer.org/How-to-install-point-of-use-water-heater.html
Gene
Water Heater Timers Save Money
Dec 02, 2014 | Franke LB2280 Instant Hot and Cold Water...
My little butler has started spitting hot water when in use.The filter is new and the temp setting has been turned down. Any ideas?
The seals have gone. This is typical of any hot water dispenser that directly heats the water while it is under pressure. The water expands and eventually ruptures the seals. Typical life time of this type of water heater is 2 years. Through it away only this time buy the non-pressurize type of instant water heater. Search the web and you will find a few brands.
Nov 04, 2014 | Franke The Little Butler LB1000 Instant...
Franke Little Butler not heating
If not tank filling ur heater wont start mostly ur soleniod valve for incomimg water spoiled. Also ur heater might be open or heater'$ thermal fuses open, if have.
Sep 22, 2014 | Franke Water Dispenser Tank Little Butler...
Franke instructions
sounds like the little butler is shorted.
Jul 03, 2014 | Franke LB1100 the Little Butler Series...
Replace Neopreme Hose on Franke FH160?
Take the whole valve and hose out and go to hardware store etc. That undersink unit is discontinued
Jul 09, 2013 | Franke LB1100 the Little Butler Series...
Water leaking from bottom of quick and hot dispenser only 18 mos old
I had the same problem. There is a 2 piece metal tank inside. The top and bottom of the tank are connected with screws & nuts, and there is a rubber o-ring between the two pieces. The grove for this o-ring is very shallow and it doesn't fit tightly, increasing the probability of misalignment during the assembly process. I was unable to fix the leak, IMHO the grove is too shallow and the o-ring is not thick enough. I decided it was poorly designed & trashed the unit.
Aug 26, 2011 | RTO Waste King AH-780-UL Quick&Hot Instant...
I can't find the reset button on my franke garbage disposal
On most franke disposers, the reset button is located inside a small indention near the bottom on the side of the unit.
Feb 11, 2010 | Franke WD-3428 Little Butler Garbage...
Slow leak drips from bottom of 4 year old model
Hi
Please try and remove the cap by turning it clockwise and counter clock wise to remove it. If it doesn't come off then empty the water dispenser and use glue to fix the leak. See this link to see which type of glue should be used--- Glue Usage
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Apr 07, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
GPS Logo
8,504 people viewed this question
Top Franke GPS Experts
Will Halftowaite
Are you a Franke GPS Expert? Answer questions, earn points and help others
