Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Bissel model 6579-3 powerforce
This model was gave to me and I cant figure out how to get dust cup apart, dirt trapped in bottom, wont come up to top, so I can empty it.
  • 1 more comment
  • Anonymous Apr 27, 2008
    power swith
  • rahjaH May 16, 2008
    Have the same problem with model 6579-3 ... have no manual ...can't figure how to remove bottom of vacuum to access what must be a clog.
  • Anonymous Mar 19, 2014
    cant get top to come off after emptying to clean
Well, i just took the whole machine apart only to realize that there was no internal clog or faulty motor parts. It was just simply the filters. the two sponge like pieces needed rinsing and the main filter had obstructions to remove. on the bright side i gained a better understanding of the vacuum cleaner. lol
Posted on Jul 11, 2008
You can download the user manual as a pdf file at www.bissell.com. Just type the model number in the search box.
Posted on Jun 02, 2008
My Bissel powerforce 6596 has suction but the dirt is not making it into the dirt cup. If I shut it off, the dirt drops to the floor. Also the motor seems to be over heating. All filters are clean. I...
Just because you cant see the obstruction doesnt mean theres not one. The hose could be stopped up somewhere not visible to your eyes. I have one and I have to take hose off and apart to clean it out. check the roller. Is it rolling?
May 17, 2011 | Bissell 6594 PowerForce Bagless Upright...
I have a bissell powerforce bagless vacum cleaner model # 6579-3. Its not suctioning up anything. What should I do?
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Aug 29, 2010 | Bissell 8975 CleanView Bagless Upright...
My Bissell will not **** up pet hair or dirt
Dirt hair and such will build up in the hoses of that vacum. Take them apart stretch them out and run something through them to make sure they are clean.
The other problem is the filter in the bottom of the cup. At least on some models there is a filter that gets totally pligged with dirt and dust. Take it apart, wash it out and them put everything back together.
Heatman101
Mar 21, 2010 | Bissell 37604 Lift-Off Pet Bagless Upright...
How do I change a belt in a 6579 Bissell ?
Here is a link to a site where you can view the manual which has instructions on how to change the belt. You can also get the belts you need here:
PowerForce Manual & Replacement Belts
Nov 04, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
http://www.bissell.com
Jun 29, 2009 | Bissell 3102-0 EasyVac Upright Vacuum
I recently cleaned all the filters in my Bissell powerforce, now instead of suction I get all blown back instead.
take all the filters out put the dirt cup back in then try it again.3 filters 1 on the bottom of the dirt cup and one above the dirt cup and one in front at the bottom behind the little door.if thats not it at the bottom on the right side you will see a clear hose thats your intake hose,one screw holds it on,take it out and bend a coat hanger so the tip is rounded ,then work it down into the clear hose ,you should be able to push the clog out through the bottom
Apr 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissel vacuum
take the dirt cup out and turn the bottom of it that will let you get to the filter,there should be some finger twist plates on the top,turn and take it out,there will be a foam cover around the filter,take that off and clean with warm warter,when done towel dry with paper towels,now the filter itself is water friendly ,take a brush and in up and down strokes ,clean while running water over it.above where the dirt cup goes is another filter ,just reach up inside and twist and it will come out,clean that also.now put the dirt cup back in without the filter and see if you have suction,i believe you will.let the filters dry before you put them back in then reassemble,and if that don't work, the take the hose off and see if you can blow through it .if thats not it then at the bottom on the right you will see a clear hose,thats your intake hose.there is a screw on the black fitting thats connected to it ,take it out and get you a coat hanger and bend the tip so its rounded ,thats so you don't puncture a hole in the intake hose.work the hanger down into the intake hose and push out the clog .then try it again..please leave feedback.i hope i was some help to you.iwould clean the foam filteres at least once a month
Oct 01, 2008 | Bissell 3522 PowerForce Bagged Upright...
Bissell Powerforce bagless 6594 W filter cleaning and reassembly
the sponge filter goes around the plastic part with tons of vertical slits on it
Aug 08, 2008 | Bissell 6594 PowerForce Bagless Upright...
My Bissel powerforce vacume filters
Remove the lower half of the dirt bowl by turning counterclockwise. Turn the filter counterclockwise, remove the foam filter and clean both with soap and water.
Jun 16, 2007 | Bissell 6594 PowerForce Bagless Upright...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
1,089 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
