Question about Microsoft Xbox 360 Console
No video first i lost the video and now i'm just getting four flashing red lights and no sound or anything.
  • 22 Answers
Four flashing red lights indicates that either the Audio/Video (A/V) cable is missing/damaged or that the console cannot detect the A/V cable. First, make sure your A/V cable is plugged securely into the back of your 360. If it is, then try replacing the cable with a new one or borrow one from a friend. If that still doesn't work, it's not the cable but the console and you'll need to call 1-800-4MY-XBOX.
Posted on Apr 15, 2008
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
The ist light and second light shone red on my xbox but i cant find anything about these lights combo and a turned my xbox on and off and it worked what happend
You may have had a loose connection from the av cable ot your power supply may have over heated. The most common thing i see in my workshop is whn the AV cable csnnot be detected, all four will flash red, but in an over heating case, you will get flashing red on segments one and three. I hope this helps .
Apr 21, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
I HAVE 4 RED RING WHEN I TURN ON MY XBOX
Solution
Mar 23, 2010 | Microsoft Xbox 360 Console
3 flashing red lights
This is called the 3 rings of death and is well known amongst xbox users. including me... Ive had 1 xbox replaced because of it. Try the following to diagnose the issue. All four lights illuminate = 0
One Light = 1
Two Lights = 2
Three Lights = 3
Example:
Turn on your "dead" xbox. Wait for the 3 red lights. Once you get them hold the "Synch" (for the wireless remote) button and the eject button down simultaniously. All four lights flash. (0) Press the eject button again and only one light (1) press again and all four light up (0) press again and two lights (2). Error code is 0102. compare this code to the table below to find out what is wrong with your X360. Is it overheating? Power Cord? Hardware? what ever the code is refer to this list for the reason it is flashing...
The Code he got was 0102 which means the computer does not know the problem as it is not hardware or heating or anything like that. Could be dust, loose solder or static! He used a can of compressed air and his X360 IS BACK!!!!!! He did not know for how long but he played several hours after and had not one Hiccup. This after a whole week of the dreaded RINGS OF DEATH!!
after you diagnoe the code get back to me and ill tell you the problem and how to fix it.
Oct 24, 2008 | Microsoft Xbox 360 Console
Red light flashes four times
4 red light flashes normally means there is a problem with the fan. Time to make a service call.
Dec 19, 2007 | Sony KDSR50XBR1 50" Projection HDTV
4 flashing red lights
  1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
  2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
  3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
  4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
site that explains codes:
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Dec 18, 2007 | Microsoft Xbox 360 Console
Sound works but no image
This means the AV cable is not detected, try one of these...
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
