Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Wont spin goes through cycle but wont spin
  • 1 more comment
  • Anonymous Dec 17, 2008
    yup. it sounds like it is spinning. clothes are still soaking wet!
  • Anonymous Dec 20, 2008
    No no burning smell just doesn't agitate as well
  • Anonymous Feb 01, 2009
    I am having the same problem....what are the things to look at to rule out what is causing this. It will go from start filling up with water, agitate, then it will not drain or spin. I manually drained it, and it will not spin. The timer will move but it will not spin.
  • 3 Answers
Could be the clutch. Is there a burning smell from the tub area? The clutch is directly under the tub. It's a royal pain to get out.
Posted on Apr 16, 2008
My dwd f1222 front loader goes through cycle but wont spin on any part. I tried moving by hand and its very loose and wont go all way around. Any ideas on how to fix please?
There is a door switch that usually goes bad. Stops the machine from going into spin cycle. Easy to replace. If you find it on the machine(plastic pointed piece on door) push the switch with your finger or a pencil. If you do nor hear a clicking sound it needs to be replaced
Apr 01, 2016 | Washing Machines
Whirlpool cabrio wtw5600xw0 will not spin
There is a spin sensor that is part of the shifter if this is wet it wont sense the spinning, hence wont spin, and if it is wet you mat need to replace the tub seal http://www.appliancepartspros.com/gearcase-motor-pump-parts-for-whirlpool-wtw5600xw0.html
May 29, 2012 | Whirlpool Cabrio Washing Machines
MY MACHINE WONT SPIN
Check the voltage to the motor when the program goes to the spin cycle. If there is voltage then check for free movement and also check on the capacitor to the motor. In some cases the high speed coil winding to the motor for the high RPM spin cycle can be faulty.
Mar 13, 2012 | Washing Machines
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Wash machine won't start in spin cycle
Lid Switch needs to be replace. Washer wont spin without lid switch.
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Having issues with my washer Model # LSR7010PQ0. Will not perform final spin cycle. All the water is draining.. basket just wont spin. Tried the spin cycle on one of the other settings and that worked. ...
As the machine goes through the cycle, it should do what is called a neautral drain (drains water without the tub spinning) then a momentary power intreupt allows the gear to slip down and the spin begins. If this is not occouring on one cycle, it is usually a bad timer.
Jun 13, 2008 | Whirlpool Washing Machines
Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Jul 23, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
