Hi there, may Kelvinator 2 -Smart drive 501- by fisher and paykel has got fulty from final rinse dose not go to spin.thanks
Hi just read your posting.Now just a couple of questions.Does your machine drain the water If it does not drain the water remove most of the water by hand so you can tip the machine back so you can look underneath .Now you will see a pump to the front right of the machine.It will have a red or black fan attached to it.Turn the fan a few times to loosen the pump if it is tight .If it loosens when you turn the fan put it back on its feet and select a spin cycle and push the start button.Hopefully it starts to drain.If it drains it should spin. Please reply with additional information or if it starts to drain.Good luck.
