Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
How to synchronize
How do i synchronize it?
How can i format?
Posted on Apr 13, 2008
Where does the cam position sencer located at
It's officially called a CMP Syncronizer.
There are stern warnings on the page associated with this.
CAMSHAFT POSITION (CMP) SENSOR Removal & Installation
CMP sensor is located on rear of engine, behind intake manifold. Before removing, note position of electrical connector on CMP sensor. Remove upper intake manifold. See UPPER INTAKE MANIFOLD . Disconnect CMP sensor. Remove CMP sensor screws and CMP sensor. To install, reverse removal procedure. Ensure CMP sensor electrical connector is pointing in original direction. Tighten CMP sensor to specification.
2 . Failure to use synchro positioner during installation will cause fuel injection to be out of time and may cause engine damage.
CAUTION: DO NOT rotate crankshaft when Synchro Positioner (T95T-12200-A) is positioned on CMP synchronizer. Armature tab will be damaged and synchronizer timing may be shifted. Removal
1. Position crankshaft to TDC of cylinder No. 1, on compression stroke. Note position of electrical connector on CMP sensor. 2. Disconnect negative battery cable. Unplug harness connector from CMP sensor. Remove CMP sensor screws and CMP sensor from positioner. Remove synchronizer hold-down bolt and CMP synchronizer.
Fig. 2: Exploded View Of CMP Synchronizer Assembly (Typical) Courtesy of FORD MOTOR CO.
CAUTION: DO NOT rotate crankshaft while synchronizer is removed from engine. Installation
1. Install Synchro Positioner (T95T-12200-A) on synchronizer housing. See Fig. 3 . Rotate synchronizer shaft until vane on shaft aligns with slot on synchro positioner. Rotate synchro positioner until engaged into notch in housing. Dip drive gear in engine oil.
Fig. 3: Installing Synchro Positioner On Synchronizer Assembly (Typical) Courtesy of FORD MOTOR CO.
Fig. 4: Positioning Synchronizer For Installation Courtesy of FORD MOTOR CO. 2. Rotate sychronizer assembly so that synchro positioner is 60 degrees counterclockwise of crankshaft centerline before inserting synchronizer assembly into engine. See Fig. 4 . 3. As synchronizer is inserted into engine, synchronizer will rotate. When seated, synchronizer electrical connector should be located in original position.
CAUTION: If CMP sensor electrical connector is not positioned correctly, DO NOT reposition connector by rotating synchronizer. This may cause fuel system to be out of time with the engine, causing possible engine damage or an engine misfire. Remove synchronizer and reinstall. See step 3 . 4. Install hold-down clamp and tighten bolt to specification. See TORQUE SPECIFICATIONS . Install CMP sensor to synchronizer and tighten to specification. Ensure CMP sensor electrical connector is in original position. Reconnect wiring to CMP sensor. Connect negative battery cable.
May 03, 2011 | 1995 Ford Explorer
Sc322
Sounds like the laser unit has failed!
SC322 - 1st laser synchronization error - • The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Poss causes:
  • Poor cable connection between the laser synchronization detector board and the LD unit.
  • Laser synchronization detector board out of position and angle of reflection not correct
  • Laser synchronization detector board defective
  • LD unit defective
If switching the machine off/on doesn't cure it you probably need a new laser unit. Has it been extra noisy before it failed? Whining/screeching/rattling?
Jan 18, 2011 | Ricoh Aficio 1035 Copier
When start the copier, functional problems SC322-00 indicated plain paper come out
322 C 1st laser synchronization error
and the LD unit.
not correct
defective
• LD unit defective
lazer problem Sorry there is nothing u can do yourself ull need a service engineer to look at it
Nov 17, 2010 | Ricoh Aficio 450 Copier
Afico 2035e - error SC326
326 C 2nd laser synchronization error
The 2nd laser synchronization signal
• Poor connection between the laser
the LD unit.
out of position
defective
• LD unit defective
My guess is that polygon mirror failed £50 -£60 if u brave enough to change it yourself
if not its lazer or sync board
Nov 08, 2010 | Ricoh Aficio 1035 Copier
Hola tengo el problema de un codigo sc-322 en una ricoh aficio 1022
Laser synchronization error
Symptom:
The main scan synchronization detector
board cannot detect the laser
synchronization signal for more than 10
consecutive 50 ms intervals.
Possible Cause:
the SBCU board
out of position
defective
• SBCU board defective
• LD unit defective
Sep 02, 2010 | Ricoh Aficio 1022 All-In-One Laser Printer
What is the problem if the the code 326 appeared?how to solve it?
ERROR TYPE C:
The main machine can be used
normally except for group
affected by the malfunction.
ERROR:
Error 326 C in the 2nd laser synchronization
The synchronization signal of the 2nd laser
is detected by the card detection
synchronization of the main scanning
Possible Cause:
Faulty connection between the card
Laser detection and synchronization
the diode laser group.
Survey form synchronization
Laser out of position
Defective Laser
Group defective laser diode...
Jul 26, 2010 | Ricoh Aficio 1035 Copier
Please solve this problem Ricoh 7650 Code SC 902, 302 and 322
SC322: Laser Synchronization Error
Definition [B’]
The laser synchronization signal cannot be detected from the synchronization
detector even if the laser diodes are activated.
Possible Causes
• Poor connection between the laser synchronization detector and the LDB
• Laser synchronization detector out of position
• Laser synchronization detector defective
• LDB defective
• SICU defective
• Front door safety switches defective
SC302: Charge corona output error 1
SC902: counter error
Mar 31, 2010 | Ricoh Aficio 1035 Copier
How can i connect my htc s20 with my pc
You will need active sync
http://www.microsoft.com/windowsmobile/en-us/downloads/microsoft/activesync-download.mspx
To install and set up ActiveSync on the computer
1. Install ActiveSync on your PC, as described on the Windows Mobile®
Getting Started Disc.
2. After Setup completes, the Synchronization Setup Wizard
automatically starts when you connect your phone to the PC. The
wizard will guide you to create a synchronization
3.Select the information types to synchronize between your phone and
computer.
If you will synchronize your phone with both your computer and
Exchange Server, do the following:
• For the Contacts, Calendar, E-mail, and Tasks items, choose whether
to synchronize them with the computer or with the Exchange
Server. These items cannot be synchronized to both.
• Select the check boxes of the other information types if you want
to synchronize them with your computer.
4.Click Next.
5. Click Finish.
When you finish the wizard, Active Sync synchronizes your phone
automatically. Once synchronization completes, you can disconnect your
phone from your PC.
After that if you setup the program correctly every time you will connect your phone with computer will be automatic synchronized
Jan 08, 2010 | HTC S620 Smartphone
Desktop manager for mac does not sync my contacts to BB 8700 only erases them at first sync however sync for calendar notes and tasks works . I have not unticked erase all contacts at first sync as I fear...
Back up information and data before changing any settings on your Mac computer:-
  1. If the BlackBerry smartphone is connected to the Mac computer, use the Eject option to remove the BlackBerry smartphone from the Mac computer.
  2. Close the BlackBerry Desktop Manager.
  3. Open Microsoft Entourage.
  4. On the Microsoft Entourage menu bar, go to Entourage > Preferences.
  5. Within General Preferences, click synchronize Services.
NOTE:-
1) To turn on contact list synchronization, select the Synchronize contacts with Address Book and MobileMe check box
2) To turn on calendar synchronization, select the Synchronize events and tasks with iCal and MobileMe check box.
NOTE:- When synchronize Services has been enabled and the OK button is selected, a new dialog window appears with the following choices.
  1. Replace Entourage items with synchronize Services items
  2. Replace synchronize Services items with Entourage items
  3. Merge Entourage items with synchronize Services items
Before the BlackBerry smartphone data is synchronized with the Mac computer, verify that synchronize Services is turned on in the Mac OS X isynchronize application. This is done by completing the following steps:
  1. Open Applications on the Mac computer and click isynchronize .
  2. In the isynchronize menu, click Preferences.
  3. If necessary, select the Enable synchronize on this computer check box.
Oct 06, 2009 | RIM BlackBerry 8700c Cellular Phone
Error SC326 on aficio 1045
Hi there below is what is states in the service manual.
the LD unit.
out of position
defective
• LD unit defective
Hope this helps you.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
