Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Beater bar works intermittently
Dear FixYa, the beater bar, light and self propel action all work intermittently on our 31913 direct drive Kenmore. The problem is not with the reset button nor a loose hose/switch issue. I believe this problem has been getting worse with time. It seems like it started on just the return/pull stroke but now the light, bar, etc will cut off and on even on the push stroke (the self propelled stroke). I took the beater bar apart to see if there was something wrapped up in the works and found some stuff but removing it did not help. Also pulled the brushes out too and they looked fine. What cuts the self propulsion off for the return stroke and what might cause the system to work in stutter steps (cutting on and off several times on each push pull)?
    President:
  • 1,673 Answers
When you push the hose into the tube, there is an acuator that will push the switch so the beater bar will turn. That switch could be just dirty, dust gets in them and they won't always work, the acuator may need to be replaced. Either that or you have a bad wire connection somewhere in the noozle or where the wires just go into the noozle asm.
Posted on Apr 15, 2008
Beater brush will not turn even with belt intact
is there any loose pieces of carpet or twine wrapped around central bar.
Dec 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self propelled upright model u6323 930
In order to have suction you need air flow.Essentialy,a vacuum cleaner is trying to create a vacuum the whole time it's on.Just because the beater bar turns doesn't have anything to do with the suction.That is created inside the canister.You have an obstruction in the hose anywhere between the motor and the power brush.
Sep 06, 2014 | Vacuums
My purple proggesive kenmore upright motor works but beater not beating help thank you
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
Nov 09, 2009 | Kenmore 31913 Progressive Direct Drive...
Unit powers up but beater bar does not rotate
Have you checked the belt that drives the beater bar?
Oct 01, 2009 | Kenmore 22812 Bagged Canister Vacuum
Self Propel wheels not enough power to move machine over carpet.
Sounds like the transmission might need an overhaul. Take it to a local vacuum repair shop and have them look at the transmission.
Sep 03, 2009 | Vacuums
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
Aug 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Direct Drive System on Kenmore 31913 Vacuum
you need to reset it on the front. overload reset button
Oct 29, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
423 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
