Question about Canon PIXMA MP170 All-In-One InkJet Printer
"Paper Jammed" Hello! A week ago I tried printing on photo paper with my printer and the rollers didn't grab onto the paper (since it was slippery) and thus began printing without any paper being in the printer! I stopped the printing process and now my printer thinks there is paper jammed, even though I am certain that there is none. What should I do? Also, it doesn't seem to want to let me scan or do anything else... very odd...
Yes I have the same problem :-( I have lots of work to do!!
Posted on Apr 16, 2008
Hello, I have a HP PSC 2335 all-in-one printer and it won't let me print on photo paper. Is there a certain setting that I need to change for it to let me? Every time I try and print it says there is a...
No setting would do that - the error is generated because the photo paper is more slippery than what the rollers can handle so they skid and the difference in their rotation triggers the jam warning message.
Just use a different brand of paper, less glossy.
Jun 02, 2011 | HP PSC 2355 All-In-One InkJet Printer
Does not always grab the paper when printing starts so paper does not feed through. Is it worth trying for a repair bearing in mind I can buy an adequate replacement for about £50. The printer is...
Try cleaning the paper pickup rollers with a cloth rag dampened with alcohol. The rollers get slippery with paper dust and they don't pick up the paper.
Nov 26, 2010 | Office Equipment & Supplies
I have a Brother DCP 195c and it wouldn't take in other photo papers! I tried to print using the free brother photo paper and it's fine but when I use other inkjet glossy photo, it wouldn't take in the...
Your glossy paper is too smooth for the rubber rollers to grab it.
You need to wet the rubber rollers. Ever licked your finger in order to turn a page in a book? Same concept solution here.
Remove the paper tray. Take a look inside the space created where the tray was, and locate the rubber rollers. Lick your fingers, and use them to moisten the rubber rollers.
Reset printer and print again. Or try "un-smooth" the paper where the rollers grab it.
Oct 11, 2010 | Brother DCP 165C Compact Color Inkjet...
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
My printer will not grab the paper
I have an R2400 and it is very finicky about grabbing the paper. I have to hand feed sheets of thick matte paper one at a time with just the right amount of pressure and even then sometimes it takes two tries. Make sure you keep the rollers very clean.
May 04, 2010 | Epson Stylus Photo R220 InkJet Printer
I am trying to print from the photo tray of my HP
Hello Michelle,
You have to go into your print settings of the application in use and select "Paper Type/Quality", then from the drop down menu you will see "Source" as an option, from there select "PHOTO TRAY".
Oct 13, 2009 | HP Photosmart Premium C309A All-In-One...
When I press print, the printer tries to take the paper, but the roller/wheels do not come down and grab the paper. Therefore, the printer says out of paper
if the paper fed rollers do not drop onto the paper it is possible the cam is jammed.
turn the unit off remove the paper and try to pull the paper fed arm downwards and try turning the rollers counter clockwise also.
if the arm drops power back up and retry a pcl command if not you may need a technician to strip the unit and adjust the cam gearing or solenoid action depending on the feed and separation capabilities
Jun 23, 2009 | HP PSC 1600 InkJet Printer
Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Jun 21, 2009 | Canon PIXMA MP190 All-In-One InkJet...
This happened to me one time after I pulled out a jammed paper the wrong way. I pulled it from the paper tray. Heard the sounds, it tried to grab the paper, but couldn't. It happened a long time ago, so I'm fuzzy on which part I tinkered with...but I recall that because I pulled the paper (backwards) from the tray, it flipped a lever/feeder/roller/thing and that 's why it wasn't grabbing the paper. If you look in the paper tray as the rollers go down to grab the paper, you'll see what's not working......sorry, lame solution.
Mar 26, 2009 | Konica Minolta magicolor 2430 DL Laser...
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Canon PIXMA MP170 All-In-One InkJet Printer Logo
80 people viewed this question
old marine
old marine
