Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Trying to replace bulb, but can't get plug to line up
Anyone have any advice on how to get the box with the lamp secured in it to line up perfectly with receiver for the plug? The only variable is the little black strip that goes over the plug itself to secure it in the box. When I took the piece apart it fell out & I have no idea which way it goes (only 2 options) but I've tried both a million times & can't get the thing to plug in.
Thanks in advance.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
If you look at the connectors there is only one way they will line up. Leave the connector on the lamp cage just a little loose so that it can move a little and that always works for me in getting the two to seat.
Posted on Apr 13, 2008
Only half a picture
"the vertical lines" is not correlated with the lamp
1,the interface between the mother board and DMD drive board
2,to clean the the interface with some alcohol
3,securely plugged
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 16, 2014 | Vidikron MODEL 65 Lamp
How to replace the bulb in a wd-65733
Its in the owner manual but generally:
Unplug the set first
remove plate beneath screen on front of set, usually pulls out or has a thumb wheel on either side on rear to back out first.
Locate the Lamp Door directly behind it and remove the screw/s that secure it.
Inside you will find the lamp cartridge, back out the two screws until the cartridge is free, and pull cartridge out by the handle it has.
Do not just buy a bulb unless you want a darker picture and a short lamp life--get a replacement with the cartridge.
A word of caution, when you slide the new one into the set take care the two pins on the lamp line up perfectly with the socket in the set where the lamp goes, it is easy on these sets to have the lamp not engage and bend the socket in the set out of position, it can be dealt with but easier to avoid that pit fall.
Door and plate and all screws etc and power set up to see what you have.
Dec 20, 2012 | Mitsubishi Televison & Video
Wtf... wd-y57 change out the bulb. timer light blinks for a min.. then lamp light strats blinking tv wont come on HELP
If you did not have this issue before replacing the lamp remove it and look to see the socket it plugs into is not bent or damaged (it is possible when inserting to not get the two pins lined up correctly.
The lamp cartridge has to be installed precisely so it plugs into the socket and also the lamp door must be closed and secured.
Mar 22, 2012 | Mitsubishi WD-Y57 57" Projection HDTV
Bulb "End of Life" message
hi,
for replacing the lamp do yhe following.
1.Remove the lamp cover by pushing two grooves lightly with the flathead
screwdriver. You can see the lamp cover on the top of the projector. ( left side of the lens)
2.Loosen the two screws securing the lamp housing until the screwdriver
goes into a freewheeling condition. The two screws are not
removable
3.Remove the lamp housing by pulling out the handle
4.Insert a new lamp housing until the lamp housing is plugged into the
Socket
5.Secure it in place with the two screws.Be sure to tighten the screws.
6.Reattach the lamp cover
7.Snap the lamp cover into place.
Replacing a new lamp automatically clears the lamp usage hours ok
Jan 27, 2011 | NEC MT1060 Multimedia Projector
Just replaced bulb. Solid yellow led with no pic
hello make sure the lamp is fitted securely and the lamp cover is fitted securely aswell good luck
regards
shaun
May 21, 2010 | Toshiba 62HM196 62" SD Television
How do you install a new bulb in the Optoma HD70 projector. Got a new bulb but no instructions
unscrew the screw on the lamp door, unscrew the lamp screws, pull the lamp out, replace with new lamp (making sure it's securely plugged in), screw it in, replace the door, plug the projector in, turn it on, enjoy!
Nov 07, 2009 | Optoma HD70 DLP Projector
Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Jul 17, 2009 | Garden
Sony Wega kdf-50E2000 Keeps turning off and on
Before you replace the lamp I recommend trying to clean/dust the lamp component and lamp plug in area. I had the same problem and was able to resolve it by simply blowing the dust off the lamp components and fan. Use a can of high pressure air to get into the cracks and crevices.
Jun 04, 2009 | Sony KDF-50E2000 50" HDTV
I need a schematic for 1999 Ford Escort Se rear brake lines
start with easy thing first are you sure both bulbs are ok ? get a test lamp
or make one!
get a good 12v bulb attach wires to side of bulb one to the terminal on base of
bulb,tape together now you can fined volts
hand brake on out of gear?
turn key on go inside car above the brake
theres a switch pull the plug off
put one end your test lamp to earth (the car body) and the other wire put to the terminals on the plug you pulled off if you get your test bulb to light its the switch thats faulty
replace switch if you have power at the switch and still no lights make a short bit of wire take back the insulation a bit so bair wire is showing make it in to a u shaped and put in to plug above the
brake that you pulled off you should now have volts(power) in the boot useing your new test lamp
to fned it make good all earthing points its somewhere between the switch and the boot?
if you fine when brake is pressed you get more than one light on its a bad earth
if you have no power at the switch ts prob fuse box fault tthry wll known for bad solder joins
good luck ps dont foget to replace plug
Jan 20, 2009 | 1999 Ford Escort
Replace headlight bulbs
Open the hood. On the top of the headlamp assembly are two 3/8 inch bolts. Remove them. Between the two (down in a hole) is another 3/8 inch bolt; it's very long, as it screws into the bottom of the assembly. Remove it, too. Slide the entire assembly forward. It's tricky because the edges get caught on the surrounding structures, but it will slide out. Remove the round rubber stopper from behind the assembly to expose the lamp. Rotate the lamp slightly and remove it. Carefully lift the retaining clips and slide the lamp off the plug. Be careful not to touch the glass on the replacement lamp; oil from your skin can cause halogen lamps to fail. Slide the new lamp onto the plug until it clicks, then put everything back in reverse order.
Oct 18, 2008 | 2005 Ford Expedition
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
