Question about GE JVM1660 Microwave Oven
Microwave part hello, I saw your post online re: ge jvm 1660 microwave. ours is doing the same thing- everything is working just fine except it won't heat. Did replacing the WB27X10489 part fix the problem? were you able to replace it yourself? How did you replace it if it did fix the problem. Thanks so much for your help. Tina
GE JVM 1660 Microwave. Everything is working fine except it will not heat.
Posted on Nov 10, 2008
  • GE Master
  • 9,086 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
Ge microwave # JVM 1660 = beeping problem
see this video and proceed according. God bless you
Oct 01, 2012 | GE JVM1660 Microwave Oven
GE Spacemaker Microwave JVM 1542WF 002 : everything works except the turntable and it won't heat. Have tried the TT on/off nothing happens. Have tried the power setting...nothing happens.
Usually, power for the turntable motor and the magnetron tube (the microwave source) are controlled by a couple of things. One is a relay on the control circuit board, and the other is a switch that's operated by one of the door latches. It's possible the control board has gone bad or bad connections have developed. It's also possible the door switch has failed or is out of adjustment and the oven thinks the door isn't closed.
Diagnosing this kind of trouble may require working on the oven while it's operating. MICROWAVE OVENS USE HAZARDOUS VOLTAGES WHICH CAN KILL YOU. You might want to leave the repair to a professional because of safety concerns. Unless the circuit board requires replacement, it's probably worth having this repaired. Unlike some repairs, this one won't cost as much as a new oven.
Jun 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge jvm 1660 and was working fine now it makes a loud noise ,it doesn't heat , but it does spin and timer etc. work. any ideas???
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 04, 2011 | Microwave Ovens
It does everything except heatinig up food. Model # JVM 3660 SD 001
The magnetron is not working. This open it and check to see if it has a blown fuse. Some microwave would have seperate fuse for the heating power. If fuse is good. You may be able to get a used magnetron from another microwave. Somtimes pawn shops would sell microwave for 5 or ten dollars just because it doesnt have a turnplate inside.
Jul 07, 2010 | General Electric Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE Profile Microwave oven
ge microwave fuses are behind upper grill and behind right side grill
Jul 25, 2008 | Microwave Ovens
Fan and Light out on GE JVM 1650
We actually repair these for customers nationwide for only $39.95 (details here).
If you'd prefer to get a new board, they run $106.94 plus shipping, and you can order one here.
prototech@usa.net
May 28, 2008 | Microwave Ovens
GE JVM1660 Microwave Oven Logo
165 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
