I have recently obtained a samsung dvds hr-735. to record on the unit i need to know which dvd channel equates to my television channel. also i dont seem to be able to get the G-Codes working. There are 9 boxes provided on the screen but there are only 6-7 digits in the tv ratings.
    Brigadier General:
  • 3,614 Answers
Can you please provide also the model of your TV.
Thanks
Posted on Apr 15, 2008
  • 4,102 Answers
Hi are you just trying to record from the telly or is it from sky or cable tv let me know ok
  • paul proctor Apr 15, 2008
    Also what country are you in
  • 1,512 Answers
If you dont have it already, you can get the manual from here.
regards
Graeme
Posted on Apr 13, 2008
  • Graeme Ross
    Graeme Ross Apr 13, 2008
    I will get on the same page as you and check it out:)
Does my JVC HR-XVC33U have a disc burner or a reader only?
Greetings Lightfingers - Your unit is only capable of viewing DVDs and has no capability for burning DVD's
If you would like to burn DVDs you can buy a burner for a PC for about $20-25 USD at a place like newegg.com.
Regards and thanks for using Fix Ya.
Mikeywaf
May 10, 2011 | JVC HR-XVC33U DVD Player/VCR
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
The manual for my DVD-V3500 says that you can't record from DVD to the VCR. But, can you record from the VCR to a DVD?
In short, no. Not with this unit on its own. No function for recording from or copying to DVDs exists with this brand/model.
A separate DVD recorder is required. I don't know of anyone who records DVDs to tape these days.
You are correct; the manual states clearly you cannot record from the DVD deck in this machine, which is a bit unusual, considering other brands of combos such as LG, SONY and PANASONIC offered an input (which was between channels or could be selected via remote) to allow DVD to VHS recording within the one unit.
I would presume you can connect this combo to the input of a DVD recorder, play a videotape and it will work via cables. DVDs last longer than tapes anyway.
Feb 03, 2011 | Samsung DVD-V3500 DVD Player/VCR
Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Mar 31, 2010 | Televison & Video
It will not load certain dvd discs
Below is a list of discs that should or should not be used with the DVD recorders.
DVD-R
4x can be used
8x will result in a disc error.
DVD-RW
2x can be used
4x will result in a disc error.
The following discs have been tested and are proven to be compatible with our DVD recorders.
MEMOREX DVD-R
FUJIFILM DVD-R
FUJIFILM DVD-RW
IMATION DVD-RW
IMATION DVD-R 2.0
TDK DVD-RW 2X
TDK DVD-R 2X
The following are brands of discs we DO NOT recommend:
MEMOREX DVD-RW
SONY DVD-RW
SONY DVD-R
TDK DVD-RW 4x
TDK DVD-R 4x
Please be aware that a free software upgrade is now available to customers. This upgrade will enable your unit to recognize the (DVD-R 8x) discs. To obtain a copy, please call 1-800-242-7158. Customer service by phone is available 7 days a week 6:00am to 9:00pm pacific time.
In order to receive the upgrade we need to know what firmware version your unit requires. First you need to access the DVD recorders service mode. Turn on the DVD Recorder and the Television, make sure the unit is on the DVD side. You may access the service mode by pressing the CMSKIP button on the remote control. Once you press CMSKIP you must press the numbers 1,2,3. You must do this quickly so it may take a couple tries. The model name will appear on the screen followed by Firmware Version. I need to know the serial number next to FE:
Press the RETURN button to exit screen.
Brian W.
Customer Support
Funai Corporation
19900 Van Ness Avenue
Torrance, CA 90501
1-800-256-2487 Customer Support
1-310-320-0571 fax
Feb 07, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units.
Christina Weate
Jun 11, 2009 | Televison & Video
Won't recognise DVD disk.
Your system needs a portion of the HDD to swap and stream for the purpose of playing and recording DVDs while CDs are small enough in their data size to play without the minimal size of the space left on your HDD which should be backed up and then erased to give you that brand new feeling.
Try it and get back to me with any problems.
Thanks for asking.
Please Rate.
Apr 22, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
Have a samsung Samsung LE26A456C and a toshiba dvd recorder. Have set up telly fine, set up video to play fine but cannot record
What is it that you are trying to record? If you are trying to record a DVD you have purchased onto a DVD-R, you will almost always run into a problem because most purchased DVDs have copyright codes burned into them, making them unrecordable. Most VHS tapes have these copyright protection codes in them as wel. If you are trying to record a television show, and are unable to do so, make sure that the DVD that you are using is compatible with your burner. If your burner is set up to record only DVD-R, then you must use only the DVD-R discs. If your burner is set up to record only DVD+R, then you must use only the DVD+R discs. Some burners will record both the DVD-R and DVD+R. If you have the right discs for your burner, make sure that the discs are correctly formatted to be recorded. Also, make sure that if you are recording from a cable box or other input that you have the correct unput channel selected on the burner. If these suggestions don't work, then it could be the brand of DVD that you have purchased (i.e. Sony,Maxell,TDK,Fuji,etc.). Check your manual for acceptable brands. I hope this helps you out. Let me know if I can be of further assistance.
Sep 08, 2008 | Samsung Televison & Video
DVDs recorded on HR720 do not play on any other player or PC!
not sure if this will solve your issue. But in order to be able to see the DVD recorded on the HR720 (or typically any other DVD recorder) you need to "lock" it. This is done in the File Manager Menu. The DVD recorder will ask you twice, whether you want to "lock" the disk. Once you have done that it will format the DVD like a normal DVD-Video, meaning it can be played on any regular DVD player. However, once locked you cannot re-open the DVD.
Hope this helps. Otherwise check in the user manual under "recording a DVD" - it is mentioned also there.
Jul 22, 2008 | Samsung DVD-HR720 DVD Recorder
DVD recorder -- displays blue horizontal lines only
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
May 02, 2017 | Samsung DVD-R4000 DVD Recorder
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
