Question about Philips Magnavox DVD/VCR Dual Player
Magnavox tv combo
My combo dvd wont work keeps saying it is loading and no dvd starts.
It first played then when it got hot it quit. Now its says loading
Pls help
  • 1 more comment
  • chumpa Apr 13, 2008
    yes I did it is a combo built into TV I hardly ever used it. I took it to sears and they said there is no parts to repair it did not even tell me what is wrong
    Yes I did and it did work for a few hrs then it started to over heat and now it is reading loading and no picture
    I actually cant record it is just a dvd player on the side of the tv I just got it last year.
    Master:
  • 377 Answers
Various issues can cause drives to occasionally balk at writing optical discs. These run the gamut of physical, hardware, and software troubles.
Inappropriate or dirty media may be to blame. Make sure to match the type of recordable disc to the drive, and check each disc for fingerprints or other contaminants. If a disc is dirty, wipe it with a clean, soft cloth in a straight line from the center hole outward. Try a quality optical drive cleaning disc if you suspect dust contamination on the drive’s laser lens.
Some discs don’t perform well with certain drives, even within their rated speeds. Try recording at a slower speed and then with a different brand of disc.
Posted on Apr 13, 2008
    President:
  • 1,944 Answers
Did you try disconnecting the unit from the power for a few hours?
  • Damen Wong
    Damen Wong Apr 13, 2008
    Also, did you try a lens cleaner? Perhaps a dirty lens is the problem here.
DVD doesn't work accepts dvd then says loading...
Hey scowtz, if your dvd is a burned copy or has other file formats that are not the most common, or I should say, basic types then it most likely will not play it. TV/DVD Combo's are made with the most basic formats. If you want to play burned copies I suggest get a dvd player and look for the formats that it plays. Usually the format label is printed on the front of the dvd player. However, if your dvd is an original that you bought from a store and it still does not play it, then its an OEM issue. Meaning you need to return it / send it for warranty / or get a replacement. I hate to say it but these dvd players built in to the tv are not the greatest and very basic so the manufactures do not put much effort in building a good quality ones. (This is only an opinion but I use to work at a home theatre dept. at a major electronic store that I probably should not disclose and these issues were common). Get the stand alone dvd players, some are quite cheap and play wide variety of formats and are actually pretty solid players. I hope this helps. Give me a feedback if this does not help. Good luck.
- Joe
Oct 23, 2013 | ViewSonic N2201W 22 in. LCD TV TV/DVD...
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
Magnavox vcr/dvd combo--dvd's play about 1/3 of the way then quit
sounds like bad pick-up unit (optical eye). these will heat up and reduce the fm envelope signal causing the optical eye to not read disc info. not worth repair. (it may could use cleaning, but usually a dirty eye will effect the movies from the beginning not after warm-up. mch
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I need codes for my direct tv box and rca tv .vcr/dvd combo
MAGNAVOX ................................ 0247
DIRECTV .......... 0863 0864 0564 0763
................. 0963 0259 0260 0263 0962
....... 0664 0065 0265 0465 0765 0866
....... 0966 0367 0567 0362 0563 0765
Dec 27, 2008 | Philips PM3S Remote Control
My magnavox model mwc20t6 keeps turning off after 10 to 20 secs
tv was working fine however when we moved it to another room it will not power on at all even using different plug ins
Nov 22, 2008 | Philips Magnavox 20MC4304 20 in....
Lightning Mcqueen TV/DVD COMBO
my lightning maqueen tv dvd player keeps cutin off what do i do
Feb 14, 2008 | Disney Ramone DVD Player
Magnavox portable dvd player
Mine does it to and it has happend so much that i started slamming the top down to get it to play, its broken. Mines a magnovox from walmart.
Dec 26, 2007 | Coby TFDVD5000 Portable DVD Player
Akai tv dvd/vcr combo- dvd play won't play
wait a bit. call the tv company. call an electrician; call a neighbor.
Dec 24, 2007 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Philips Magnavox DVD/VCR Dual Player Logo
77 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
