Question about Compaq FS7600 17" Flat Glass Monitor
Red screen i went out of the room for a bit and when i got back the black on my screen is red. i tried to change the colors and all but nothing worked. is my monitor color module (or whatever it is) gone? Is there any way to fix it?? Please help, my computer is important to me. Thank you Earla
  • wytch13 Apr 13, 2008
    my monitor is crt. i tried reinstalling the video card but the black still has a reddish tint and the colors still arent right. I also tried the monitor menu and fixing the colors, nothing has worked.
  • Ajemy  Rashid
    Ajemy Rashid May 11, 2010
    Your monitor is CRT or LCD ?
  • 180 Answers
It is possible that solder joint at the back of the tube is dry.
resolder it.
Have a try
TIA
Posted on Apr 16, 2008
  • Ajemy  Rashid
    Ajemy Rashid Apr 17, 2008
    Does it it solve your problem . just let me know.
resolder it.
Have a try
TIA
Power outage now tv doesnt work
It should be under warranty. do not panic. Call the manufacturer as soon as possible.
Jun 08, 2017 | LG Televison & Video
Digital Lifestyles 42" LCD HDTV
How many hours has the tv been used ... approx... as this will reveal further solutions..
Jun 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Picture is very dark and color not too good.
Take the front speaker grille off; it is stiff but will pull off. Take off the access panel underneath; four or five screws. Inside you will find a screen/focus block control assembly. Get a flashlight. Turn up the screen controls SLIGHTLY. for RED, GREEN AND BLUE. The best way to do this is to turn off the color first and make sure you end up with a good black and white pix ( not tinged green, red or blue) then turn the color back up in the menu.
May 11, 2009 | Televison & Video
Dropped laptop, color on screen not natural
The problem could be that you jolted a heat sync or fan loose that cools the video adapter. If you power off the machine and let it sit for several minutes and then reboot and the same thing happens, its a heat issue. Laptops have the graphics card in a chip form soldered to the motherboard, thats not the issue. Undoubtedly you have jostled something loose. If in fact it is a heat issue, you can have someone take the laptop apart and reseat the heat sync or maybe check on the fan that cools the video adapter.
Mar 21, 2009 | HP Pavilion dv2000t Notebook
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Compaq FS7600 17" Flat Glass Monitor Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
