Mathematical Technologies Inc. MTI Tristan Soaker Tub  Logo
Posted on Jun 15, 2010
Multiplication table - Mathematical Technologies Inc. MTI Tristan Soaker Tub
Anonymous
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Aug 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
10204
Points
45
X 01 02 03 04 05 06 07 08 09 ...
01 01 02 03 04 05 06 07 08 09 ...
02 02 04 06 08 10 12 14 16 18 ...
03 03 06 09 12 15 18 21 24 27 ...
04 04 08 12 16 20 24 28 32 36 ...
05 05 10 15 20 25 30 35 40 45 ...
06 06 12 18 24 30 36 42 48 54 ...
07 07 14 21 28 35 42 49 56 63 ...
08 08 16 24 32 40 48 56 64 72 ...
09 09 18 27 36 45 54 63 72 81 ...
All combinations of numbers
34=2*17
39=3*13
1326=2*3*13*17=2*663
1326=3*(2*13*17)=3*442
1326=(2*17)*(3*13)=(2*3)*(13*17)=6*221
1326=(2*13)*(3*17)=26*51
1326=34*39
The table is called the multiplication table
2answers
Bailey hi-low table will rise 2 inches at a time. Why?
unfortunately that is the way to raise the table. it is easier to do it if the before the client is lying down on the table if possible
4answers
Where can i buy a chiropractic table?
there are many sites and shops that sell chiropractic tables. you should figure out first of all what kind you are looking for. Here is one good site where you can personalize your table;
http://www.elite-chirotables.com/index.php
Jan 14, 2013 • Medical
Should I buy a Hann drafting table?
These drafting tables are really fancy. The tables are made from hardwood and the surface from fiberesin. They come with lots of features. You can buy a table with drawers, a keyboard tray, wire organization, and more. There is plenty of space for a computer and multiple documents.
Jan 07, 2013 • Furniture
I want to format java code and later want to check whether it got formatted, using checkstyle. How can i do that
write a program that get an input size from the user and print the multiplication table with the specified size :
size of the multiplication table 5;
multiplication table of size 5;
3helpful
Can you run a dado blade on this saw?
The 15 amp 3 hp motor has plenty of power to handlee dado sets and you can purchase a dado blade insert for the saw on line from multiple resources
Application and example of relationship in access
Relationships
After you've set up multiple tables in your Microsoft Access database, you need a way of telling Access how to bring that information back together again. The first step in this process is to define relationships between your tables. After you've done that, you can create queries, forms, and reports to display information from several tables at once.
A relationship works by matching data in key fields - usually a field with the same name in both tables. In most cases, these matching fields are the primary key from one table, which provides a unique identifier for each record, and a foreign key in the other table. For example, teachers can be associated with the students they're responsible for by creating a relationship between the teacher's table and the student's table using the TeacherID fields.
Having met the criteria above, follow these steps for creating relationships between tables.
  1. In the database window view, at the top, click on Tools ---> Relationships
  2. Select the Tables you want to link together, by clicking on them and selecting the Add Button
  3. Drag the primary key of the Parent table (Teacher in this case), and drop it into the same field in the Child table (Student in this case.)
  4. Select Enforce Referential Integrity
    • When the Cascade Update Related Fields check box is set, changing a primary key value in the primary table automatically updates the matching value in all related records.
    • When the Cascade Delete Related Records check box is set, deleting a record in the primary table deletes any related records in the related table
  5. Click Create and Save the Relationship
Access 2007 forms wizard
If you run a repair install of office 2003
Access Pasting Multiple data in the table
When pasting data between tables, you have to make certain to select the exact number of rows and columns that you are going to paste into. For example, if you are pasting ten rows and ten columns of data, select (highlight in) from source table, Control C to copy, then go to destination table, select (highlight) ten rows and ten columns, then paste, either by right click and paste, or Control V.
This should solve your issue, but if not please post back. Thanks for rating FixYa!
Top Mathematical Technologies Inc. Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Mathematical Technologies Inc. Home Expert? Answer questions, earn points and help others
