Why does my 61'' 2006 hdtv comes on for 30 seconds then shuts off, it constantly does this, purchase in 2007, just started doing this when i moved to a different city two weeks ago
Most likely you have a bad battery. The second option is that you have a faulty wiring and there is a constant load that takes a lot of power, but it does not make a short circuit. Check the electrical relays, maybe it's in them.
to change a ballast board its a bit of work and a tear down to get it in there . but first lets review your problem .
its cycling off every 30 seconds . id suspect a defective lamp or a power supply problem since it sounds as if the ballast board does fire . that's assuming that you do see something come up on the screen when it attempts to start if a ballast has failed it usually will make a noise or the set would almost go into a shut down . also how many blinks and what order are the events happening ?
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
