Question about Video Game Consoles & Games
My xbox 360 was working fine ,and a few hours later I put the same disc in , and it says the box cannot read the disc. i removed the disc, washed it with soap and warm water , dried it with a clean cloth, and I still get the messsage. I got this disc in dec. It has no visible scratches, but does show a circular ring on it. ALSO..is there a right and wrong way to store my xbox??Does it have to sit a certain way??
The problem is in your disc couz they have an ring inside the disk
Posted on Apr 13, 2008
  • jeffrey manarang Apr 13, 2008
    maybe check ur xbox 360 check your lense
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Everytime i put in a game in my 360 it says open tray
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Mar 17, 2010 | Microsoft Xbox 360 Halo 3 Special Edition...
Xbox 360 wont load any disc and have tried 7 steps of repair on your websitse and it still wont work
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this mayhappen:
Jan 15, 2010 | Microsoft Xbox 360 Console
I am playing Modern Warfare 2 on my Xbox 360 and after about 20 minutes it quits reading the disk. Any clue on how to fix this? Other disks work just fine.
Check the disc for any scratches. Clean the disc with some disc repair solution. If you just purchased the game try and take it back to where you bought it for an exchange. If there is no scratches or anything that could stop the disc from reading right it could be your Xbox. Xbox has been known to have many issues with heat maybe your Xbox is getting to hot. In which case the problem is your Xbox and you will have to call Microsoft about getting a new Xbox. My Xbox started to go bad in the exact same way. I would play multiplayer for awhile and it would freeze after playing for a little while. I would then turn the xbox off for a few min then turn it back on and it would work again for awhile untill a few days later when i got the red ring of death which means a hardware fail.
Dec 26, 2009 | Video Game Consoles & Games
My old x-box 360 has red rings and i dont want to pay to repair it so i need a thing to fix it i guess.
Remove the harddrive, remove game discs, turn XBOX on, remove anything external (ie internet, fans) wrap in 2 or 3 large bath towels and completely incase the console. Make sure no gaps or air can find it's way to the XBOX.
This is a temporary fix, it may work for a few hours to a few days. If you get it the RRD again, follow these steps until you buy a new XBOX.
Call the 1800 number and put the serial number in to see if it's still under waranty because some were extended.
Dec 05, 2009 | Microsoft Xbox 360 Console
Xbox 360 not reading discs
Nov 17, 2009 | Microsoft Xbox 360 Console
Wont read games
Though i fixed the Disc Read Error myself within anhour but please test the below method at your OWN Risk. Please alsonote that microsoft is no longer providing Extended warranty for E74Error.
Check out this DIY Video Guide,that explains step by step instructions to fix Disc Read Error yourselfwithin an hour. It also provides the money back guarantee in case youare not satisfied. As i fixed my Xbox myself so i thought to share itwith you guys.............
Mar 03, 2009 | Microsoft Xbox 360 Console
XBOX 360 disc reading problem
Yes! you can contact Mircrosoft, the number can be found on the box that your 360 came in... call them and let them know that your Xbox no longer reads disks and they will send you a box in which you can send them your Xbox and they will repair it and send it back to you Free of Charge! It takes a few weeks to a month to get your 360 back, but it's worth the wait when it's working perfect again!
Hope this helps :)
May 17, 2008 | Microsoft Xbox 360 Console
Game just stopped
The xbox 360 is to old or it heats up
May 03, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
