Ink Jet Waste Tank
Printer says waste tank is full? What can I do?
  • 74 Answers
Try this website
http://www.polyphoto.com/tutorials/PrintHeadCleaning/CanonCleaningAndReset.html
Let me know if that works
Mitch
P.S. Don't forget to leave feedback
Posted on Apr 13, 2008
SOURCE: waste ink tank full
please help me for repair waste in tank full canon ip3300.
Posted on Jan 24, 2008
SOURCE: waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Posted on May 01, 2008
  • 49 Answers
SOURCE: Canon printer i 475D
This may be worth a try
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Jul 03, 2008
phantomtech
  • 20 Answers
SOURCE: Ink Waste Tank Almost Full on Canon i320 printer
Hi, This procedure should work.
Waste Ink Counter Reset.
Step 1 : Manual for service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
or
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Posted on Jul 25, 2008
JongCur
  • 88 Answers
normally, the logical solution is to replace your waste ink tank, but I have tried a solution which could make your canon printer function again.
Try this: With your printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Posted on Oct 06, 2008
Canon BJC- 1000 LPT 1 printer. STATUS: the used ink tank is full. printer not performing.
HI,
Your printer has a built-in waste ink tank for the ink used during print head cleaning. As time goes by, the waste ink tank gradually fills. When the waste ink tank is nearly full, you should receive a "Waste ink warning" error when you print. Press the RESUME button on the printer to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, have the waste ink tank replaced.
Jul 08, 2008 | Canon Office Equipment & Supplies
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Waste ink tank over flowing??
Hi, like every ink jet printer, there should be an ink pad(spunch) at the bottom of the printer to collect the waste. That spunch might be full of ink. You could locate it, remove and try to clean it under the water. See if it works
Apr 03, 2009 | Canon i860 InkJet Photo Printer
Pixma Ip90v waste ink tank full
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Dec 16, 2008 | Canon PIXMA iP90v Printer
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
Aug 23, 2008 | Ricoh Office Equipment & Supplies
Waste ink tank full
Nov 01, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
149 people viewed this question
jasbo
jasbo
