Question about Dell Inspiron 1000 Notebook
Dell laptop mo.1000 inspriron
Computer won't start. sometimes it will for about thirty second
i check power cord ok, only one light on computer comes on
this is first time problem for my computer ernie m.
  • sondrajohnso Apr 21, 2008
    We have the same problem... Anyone out there have a suggestion????
    Scholar:
  • 99 Answers
There could be several things that could cause this actually.
1. the power supply could be bad and is not giving the correct voltage to the system board and thus it shuts off.
2. The voltage on the system board is overloading the Computers Processor so it shuts down
3. The Processor has or is going bad.
If you have another power supply or can borrow one, that would be the first thing I would try. If that doesn't fix the issue, you will need to have it serviced by a professional who can trouble shoot the problem with the proper equipment.
Posted on Apr 25, 2008
My inspiron 1000 laptop from dell won't turn on. The adapter cord is not getting hot. I was defragging the computer when it shut off. Is this the adapter cord?
Hello there:
ok the first thing that i would suggest is to remove the battery and unplug the power cord from the computer
now check the area that the battery connects to and get a q-tip and some rubbing alcohol and clean the contact areas where the battery connects to the computer at really good and let dry
next if the computer has a reset hole on the back of it use a toothpick or somthing small and press in on the reset for 2 min and than release than press and hold in on the computers power on button for one minute and release now plug in only the power cord and turn on the computer and it should now start
than after it does put the battery in and let charge for a min of 30 min
than you should be ok from there ok
Please feel free to post a comment to me if you still have problems ok
Hope all of this is very helpful for you
Best regards Michael
Dec 19, 2009 | Dell Inspiron 1000 Notebook
Dell inspiron 1526 has problem (plugged in ,not
Hello there:
First you will want to ensure that the power cord is fully inserted at both the laptop and all the connections for the cord and that it is getting proper power. and check tosee that the connector thatthe power cord goes into is not loose if so this will have to be repaired
next remove the battery from the computer and unplug the power cord and then press in the power button for 1 minute than if this has a reset button on the back use a toothpick or a small item and pressin on the reset button for 30 seconds
now insert the power cord (NOT THE BATTERY YET)
and turn on the computer and it should now start up if so insert the battery and leave charge for 1 hour than you should be ok from here ok
Please keep me posted on this so i can assist you if needed.
Best regards michael
Dec 16, 2009 | Dell Inspiron 1526 Laptop
Inspiron 1000 green lights come on, no fans, blank dark screen, no cursor
Check your RAM chips. A bad RAM chip will cause this symptom. Could also be a bad MB. But check the RAM first since it's a much cheaper fix. Might also just need to be reseated. After reseating, pull the battery and power cord. Press the power button for about 10 seconds. Then reinstall battery and power cord and try to reboot. If symptom persists, it's likely the MB.
Sep 16, 2009 | Dell Inspiron 1000 Notebook
Failure to power up
Check the cable and do power on self test(POST)
Aug 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Heard pop and dell vostro 1000 cut off and will not come back on
Based on the symptoms (Power light on cord is on when not connected to laptop but goes out as soon as you plug it in), the motherboard has to be replaced. YOu may call dell to ask about their out-of-warranty depot or you can call their spare parts sales dept to purchase the motherboard, then find a local tech to replace it.
Jun 16, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Inspiron 1000 will not power up. power ligth is on but does not go to next stage
check the laptop power ic power light is on then not come to dieslpy mis power ic problem .............ok change the powr ic
Apr 03, 2009 | Dell Inspiron 1000 Notebook
My dell C840 wont power on.
well if the laptop worked till there was charge in the secondry battery its an issue with the cord or the port that connects the powercord to the laptop. ie the inlet on the laptop. check these two as well.
Mar 29, 2009 | Dell Latitude D830 Notebook
Dell latitude 100L will not start
Couldnt tell you if its going to solve your problem but you can get a cheaper replacement rechargeable battery here - Dell 100l battery, also good for the inspriron 1100 and 5100 range
Dec 24, 2008 | Dell Latitude 100L Notebook
AC adapter for dell laptop inspiron 2200
You can order the part from this link
Dell_PARTS_ADAPTER
Once you open the link scroll down and select the second adaper in the list
60 Watt 3 Prong AC Adapter with 3-ft Power Cord for Dell Inspiron 2200 / Latitude 110L Laptops
May 20, 2008 | Computers & Internet
Dell Inspiron 1000 Notebook Logo
47 people viewed this question
Alun Cox
