Receiver Problem. I have a Yamaha CR-420 Receiver and the volume control doesn't work very well. The sound cuts out and has a lot of static most of the time. Do I need to replace the volume control or can I fix it?
    Genius:
  • 1,689 Answers
The following is if you feel comfortable to work on your reciever.
Before replacing the volume control, go to any local electronics parts supplier and get some circuit control contact cleaner.
Disconnnect the AC cord of the reciever, open the reciever and get access to where you can spray some of this in to the control to clean it. After using the cleaner rotate the control back and forth at least 20 to thirty times.
It is recomended to not get any of the cleaner on the circuit boards if possible. With normal electronics there is no danger, but it can promote the accumulation of surface dust over time.
If the cleaner does not do the job, then you will have to replace the control. For this you would have to order the original part from the manufacture, unless you can retrofit a generic type varible resistor in to the set. The problem with retrofiting is that you will have to be able to match the resistance, characteristics, and mechancial mounting and fitting the knobs.
For the cleaning of the control or for replacing it, I would suggest having a service tech do this for you unless you are experienced in this type of work. It would be safer for you, and there would be less risk of damaging something.
Jerry G.
Posted on Apr 13, 2008
Yamaha rxv 870 - volume does not work from remote(s)
hi i have the same problem. yamaha rx-v870 with a remote control that works perfectly except for the volume up/down. i pressed the buttons for a minute and applied some lemon gunk remover liquid and this helped for a very short period. i am wondering if the problem is with the little motor inside the receiver that rotates the volume knob itself, as opposed to an infrared problem on the transmitter/receiver.
Dec 24, 2012 | Yamaha RX-V870 Receiver
Sound cuts off, but if I touch the master volume contorl knob it comes on for a short time. Do I need a new knob, or something else?
Possible that there is fault in the preamp analogue/logic control. When you touch the volume control knob the static from you partially injects the circuit to work and thereby conduct to produce the volume.
The volume controller is an analogue rheostat coupled to a circuit that can be the suspect , it can even be a fault- open circuit- of the controller.
You can remove the top cover after disconnecting the power supply and check behind the volume knob for the circuit. If you are able to test this circuit , it will confirm the case.
Oct 07, 2011 | Teac AG-D9100 Receiver
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
There is persistent low volume humming sound coming through all the speakers when the reciever is on, it is just loud enough to interfere with the audio I'm trying to listen too (especially dialog on the...
You could have done a very slow damage to the Yamaha if your UPS was not a pure sine wave type ( on line UPS ). Most of the UPS we get are called Off line type and are far cheaper than the On line pure sine wave type. The out put of the Off line type UPS is not a sine wave ( the natural waveform of AC voltage ) and strains the Power supply circuit of any device connected to it.
Now if the humming sound is the same irrespective of the volume position, it is a power supply problem. You might be having a leaky rectifier diode or capacitor. First change the diodes and see if its ok then change the main filter capacitors too.
Apr 28, 2011 | Yamaha RX-V663 Receiver
How much for a digital board for my yamaha a/v rxv 420 ?.an expert check my a/v and tell me the problem is the digital board.
What concerns me is why do you need a digital board, which cost around $150 or so. I just repaired a rx-v620 that needed the volume and mode crols replaced. These controls affected mant aspects of the digital circuits opperation. Your 420 could have a similar fate. What is it doing?
Jul 17, 2009 | Yamaha RX-V420 Receiver
Audio volume control problem
Have exactly the same issue, no cure however
Mar 16, 2009 | Audio Players & Recorders
Roland keyboard. Extremely static-y speakers. Cuts out.
It sounds like your volume slider is dirty. Try carefully and judiciously spraying a good quality contact cleaner into the slider and working it. do not use a lot. It only takes a little. Also do not use WD40.
Mar 01, 2009 | Roland Juno-D
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Remot control dont working
dropping to a hard floor is always the reason when remote dont work.change the transmiter led or check some crack inside.clean the board and the rubber button with alcohol.
Oct 21, 2008 | Yamaha RX-V420 Receiver
105 people viewed this question
 Grubhead
Grubhead
