Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Power problem I have my Progressive with direct drive for 3 weeks. I was using it today then stopped. When I went to turn it on again nothing no power at all
    President:
  • 1,673 Answers
With out checking it, it is hard to say, I think there is a reset, did you push it? But you do have a years warranty on this, that it into Sears for repair.
Posted on Apr 15, 2008
Manual for Kenmore Progressive Direct Drive Upright Vacuum
can some one show via picture of the location where the micro switch is where the hose attaches to the progrssive direct drive vacuum cleaner to get the start brushes rolling again,
Sep 28, 2010 | Kenmore 31913 Progressive Direct Drive...
The brushes will not turn when on and cannot move them even manually
Drive belt has most likely broke and jammed inside the power head. Remove the bottom plate on the power head and replace the drive belt.
Oct 07, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Vacuum roller stops turning
with cleaner plugged in and turned on, push the little reset button on the side of the lower base of vac. Remember that the brush will not turn in the upright position. release your handle and you should be in business. hope this helps. please let us know. thanks renevacdoc
Jul 22, 2009 | Kenmore 31913 Progressive Direct Drive...
I have a kenmore progressive direct drive handi mate jr. upright vacuum. My daughter used it last night to vacuum up some cat litter that had spilled on the floor. I went to use it today and it turned on...
its probably clogged up with cat litter.might have gotten into the motor.your motor has a motor guard inside if it. when it overheats it will shut down till it cools off.you need to clean all th cat liter out of it.and clean the filters.with a direct drive you might want to take it in to a repairman to sevice. its not a shop vac i advise you not to pick up things like cat liter
Apr 28, 2009 | Kenmore Vacuums
I have the upright kenmore progressive with direct drive and the filter canister stops bringing in air and picking up when hose is put into vaccum, when you remove hose and use as an attachment it starts...
Check the hose after the brushes. With this problem there is normally a clog in between where you disconnect the hose (to use attachment) and the brushes that clean the carpet.
Dec 21, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Upright
same problem.... roller won't turn, nothing stuck in it.... no solutions?
Jun 20, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
May 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Will not start at all
most likely if it dont turn on at all period.1 of 2 things on/off switch went out or 2 motor burned up but most time u can tell if it is bad motor cause if it smelt like burnt plastic ever bad news its dead but hopefully u can just change switch
Dec 15, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
81 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
