Question about Euro-Pro HEPA Shark EP238 Bagged Canister Vacuum
My hose cracked on my ep238
I need to see if you can help me find replacement hose for my vacuum. thank you for your time. wandaly
  • luciacovelli May 11, 2010
    Where is it cracked? My hose cracked and I fixed it with duct tape. It held great for 5 years.
I've had the hose brake on this vac at both top and bottom several times. You can pinch the ears that hold the hose assembly to the wand and vac connection and get at the piece that the hose screws into. Remove the old piece, cut the hose cleanly and screw back in, then snap back together. They don't seem to have this hose anymore and since the vac also has problems with its cord assembly I'd say your best bet is a new vac once the hose can't be fixed anymore.
Posted on Jan 21, 2011
Doesn't suck
Vacuum Cleaner Repair Help
How to Fix Vacuum Cleaner
How to Fix Vacuum That Lost Suction
If there's ample suction but the machine won't pick up material, check the hose for blockages. Disconnect the hose from the vacuum cleaner and inspect it for any cracks or holes. If any are found, use duct tape to repair them - it might not look great, but it does the job! Where there's a blockage in the vacuum cleaner, clean it out by pushing a long, thin object like a broom handle through the entire length of thre hose. You can then reconnect the hose and try the vacuum again. It's worth checking the hoses a few times every year for cracks or splits.
If everything else appears to be fine but the vacuum still won't pick up, take a look at the brushes. Turn the vacuum cleaner upside down and clean hair and other material from the brushes, especially at the sides.
How to Troubleshoot Vacuum Cleaner DoItYourself com
Jul 24, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
Loss of suction from base but ok from hose. filter cleaned and dried
When the Cyclone Assembly on the Dyson is not spinning around, it usually means that you are loosing suction somewhere. This can either be caused by a clog, suction leak, or dirty filters. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem # 1. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the vacuuming position with the handle down. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the handle was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
hope this helps you .........
Mar 11, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
Cracked hose Shark Navi SV1105Z cordless
There are not many replacement parts available for your model
Jan 22, 2014 | Shark Navigator Bagless Upright Vacuum
There is no suction in my vaccumm
CHECK LIST
1. Full or clogged dust bag.
2. Dirty air input filter.
3. Wrong pile height setting.
4. Open suction control.
5. Hole in hose.
6. Canister hood open
this link is for the manual
http://www.sharkclean.com/manual/EP238_0602A_1yr_warr.pdf
Sep 26, 2012 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Need bags for the euro pro x ep 238
Needed bags for this vacuum and FINALLY found them at http://www.totalvac.com/parts/X10-3005.html?zmam=6843742&zmas=1&zmac=6&zmap=X10-3005. Ten bags and two filters for $10.95 plus shipping. Hope this does it for you and anyone needing bags for this vacuum..
Aug 06, 2012 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Hi... I'm getting no suction from the hose at all. Have checked hose for clogs but couldn't find any. Cleaned filter. Have no suction when vacuum is in position to clean floors. Checked for...
Anyone owning a bagless vacuum cleaner,
needs to own a small air compressor, to blow
it out after every 2 or 3 uses
Otherwise is will never work,too clogged up
Jun 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Model UH60010, Series X12.0, Mfg code K09A. While attempting to use the hose and the extensions to clean shelves, my wife reported no suction. I removed the brush roller and the plastic piece just below...
There are six different reasons a vacuum can lose suction, a plugged vacuum hose, bad motor, full vacuum bag, or cracked or damage hoses. Purchasing a vacuum cleaner can be a costly expense while repairing the suction on the unit can be virtually free. Most suction loss problems on a vacuum can be easily fixed or remedied with common house hold tools and very little technical expertise.
If your vacuum cleaner losses suction, the first and easiest solution is to check the bag. If the vacuum cleaner bag is full suction will be greatly reduced and the unit will become ineffective. A vacuum cleaner works by passing air through the bag fibers leaving dirt and debris behind inside the bag. If the refuse bag becomes full, airflow is restricted, limiting the amount of air passing through the vacuum bag resulting in loss of suction. When replacing the vacuum bag always consult your owners manual to insure that the vacuum bag seals with the vacuum inlet hose. If your vacuum cleaner bag is not tightly sealed to the vacuum inlet hose you will decrease the air flow through the bag resulting in loss of suction.
The second and sometimes most common reason for loss of suction on a vacuum cleaner is a plugged vacuum hose. If the hose becomes plugged, air flow will become restricted. To unplug a vacuum hose detach it from the machine and inspect the inside. If there is a restriction in the hose, remove it with your fingers and replace the hose onto the unit. If the hose is long and the debris is hard to get too, a broom handle or other long object can be passed through the hose to dislodge the debris. Most vacuum cleaners contain more that one suction hose, so make sure to check each one by process of elimination. Another area that can become easily plugged on a vacuum cleaner is under the lower base of the unit by the roller brush. Large debris can get caught in this area and restrict air flow to the hose.
If your vacuum refuse bag is not full and the suction hoses are not plugged the next thing to check is the condition of the hoses. Many hoses are made from plastic which can easily tear or crack. If your vacuum cleaner shows signs of wear or are cracked they need to be replaced. Even the smallest hole in a vacuum hose can leak enough air to greatly diminish the suction potential of your unit. Replace your vacuum cleaner parts with OEM parts from the original manufacturer to ensure the tightest fit.
Most vacuum cleaners contain filters. Filters are used as a last line of defense to remove dust and smaller debris particles before the air is recycled back into the environment. If vacuum cleaner filters become dirty or plugged they also can decrease the amount of air traveling through the unit. Some filters can be easily rinsed with water whereas others need to be replaced. It is important to check your owners manual before rinsing a vacuum filter.
The last and probably least common problem for a vacuum cleaner to loose suction is a bad or failing vacuum motor. Over time vacuum motors lose power due to worn carbon brushes or long term damage. A vacuum cleaners worst enemy is moisture. If water or moisture is sucked into the vacuum motor it will greatly diminish the amount of suction the unit has. Replacing a vac motor can be a costly and time consuming ordeal. In some cases, replacing a vacuum motor can outweigh the cost of buying a new vacuum. Vacuum suction is measured in water lift which can easily be measured by using a water lift gauge. If the water lift measured in inches, falls below half the original water lift specifications for the unit, it is time to replace your motor. Most vacuum cleaner repair shops carry this type of equipment and can easily tell you if it is time for a new vac motor.
Jul 25, 2010 | Vacuums
My upolstry ad=ttachment is not working no sucking up dirty water
Greetings from GoVacuum,
This is a frequent problem for the Hoover SteamVac models. What's usually happening is that the hose on the vacuum cleaner is damaged, and needs to be replaced.
You can verify this by reclining the handle of the SteamVac all the way down to the ground. Then take out the dirty water solution tank from the SteamVac. You can see where the hose connects into the steam vac, 9 times out of 10 the hose will be cracked right at the point where the end of the hose is connecting into the SteamVac, and needs to be replaced.
There are several different versions of this attachment hose, varying from model to model. If this is the problem,a nd you would like to know which hose goes to your specific model, please send me an email to chris.jones (at) govacuum (dot) com.
Also if this is not the problem, please just request a clarification for this page, and I can help you further diagnosis this problem.
Thanks,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Euro-Pro head cranky
The air driven head is probably bond up and needs to be cleaned. Alot of the air driven ones have a belt that may be broken or stretched.
Jan 10, 2008 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Open Questions:
Burned out The best way for me to describe the problem is to post reviews I made on Amazon.com, which is where I purchased them. ________________ Based on my past experience, I bought another 6 months ago. I live in a very tiny 2 room apartment and do not vacuum lots of dirt. I noticed this new vac getting very hot to the touch where the motor is located with only a few minutes of use. Today it just STOPPED. When I felt the canister, it was HOT. It obviously has burned out. Upon closer inspection, (removed the inner filter that sits just behind the bad) I noticed the construction of this vac is different from the older one. They are IDENTICAL in every way, until you look inside. This one has more plastic covering the fan area. This design obviously does not allow as much air circulation to cool the motor. Therefore, this is a DIFFERENT vac than the one I purchased years ago which ran so well. They were both the same model #. If I had instructions to follow as to how to take this apart, I could probably fix it. I have fixed many things that way, even without instructions, just paying close attention to taking them apart. I just don't know where to begin to take this apart properly. Thanks for any help. I am not going to send it back, even though it is under warranty and is practically brand new because I barely used it. Based upon reviews, the company now outsources repairs and shipping cost to the customer is exhorbitant. That reviewer also mentioned that they took the vac to a local repair place and they could not service it because of the brand (?) All help appreciated. _____________________________ I have used this vac nearly every day for 5 years, and the suction has been extremely powerful. I never had a problem with it, and I have sucked up LOTS of dirt with this thing! I never liked the carpet attachment, and used a brush from my old Electrolux attached to the Hepa Shark wand. Unfortunately, today I did something very stupid and ruined my vac. A light bulb broke on my deck and rather than sweep up the glass, I thought I would do it the easy way and vacuum it up. My deck "looked" dry, but evidently, was wet from a recent snow, and when I vacuumed the cocoa door mat, lots of water was suctioned up into the motor. It made a noise and when I removed the disposable bag, it was ripped. The vac was FULL of water :( I have never seen one of these in any store in my area, so I immediately got online to order another one.. Then I read all the negative reviews and am afraid to purchase a replacement. Was I just lucky in getting a really good one? This vac is the perfect size for a small apartment. I have a dog and need to vacuum often, I need a hepa vac and hate the bagless types. I purchased this vac after my 25 yr. old Electrolux died, and every other vac I used never seemed to have the powerful suction as this little thing, except the $400, models. Now I am trying to decide if I should take a chance with this. It is hard to find the bags, but I was able to purchase them from a vac & sew outfit in TX. What to do??? UPDATE: May 24, 2005 I dried out my wet motor and my Euro-Pro Shark EP238 HEPA Vac has been working great! I'm glad I did not purchase a new onw, as this old thing seems to have 9 lives. I must have been lucky, as so many others are not happy with this product. 2nd UPDATE : March 8, 2006 I am pleased to report that my little vac still performs as well as it did when new, in spite of the water exposure. I would go as far as upgrading my original rating to 5 stars. I think the secret to its good performance is in keeping the inner filter as clean as possible. Hope I have not jinxed my luck in expounding on the virtues of this machine!
Feb 26, 2017 | Euro-Pro HEPA Shark EP238 Bagged Canister...
Euro-Pro HEPA Shark EP238 Bagged Canister Vacuum Logo
180 people viewed this question
Top Euro-Pro Vacuums Experts
Roger Potts
Tony C
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
