Figidainre front loading washer
Had washer for over a year. wife lost necklace thought it might be in washing maching, took total shell off unit, removed the boot infront of the pumg which contained coins but no necklace. put every thing back together. now when washer is in spin cycle washer shakes violently. washer is level. can't figure out what to do
  • Kurt Ness Apr 13, 2008
    I check the shocks and they seem to be fasten securely. still shakes violently in the spin cycle
  • Washing Mach... Master
  • 19,396 Answers
As first step ensure the machine is level. The feet have screw adjusters to do this with. Some have so called self levelers on the front but they often stick after a long use.
After checking level make sure the load is evenly distributed in the machine, and machine is not overloaded.
After ensuring is not any of the above, check the braces at the top ot the tube that keep it lined up,If you clothes are not off balance in the tub. one of these braces has come loose or broken , most probably broken.
Regards
Posted on Apr 13, 2008
    Sergeant:
    Champion:
  • 427 Answers
Try to make sure that the load is distributed properly.
    Genius:
  • 1,073 Answers
Shure that you secured all the shock mounts and springs, just a thought
How to replace samsung washing maching WT8202 timer
No offense but I have the same model. those front loaders are no good and as hard as I try to say good investment aint gonna happen so please don\'t tell my wife I say get rid of it now or put money back every week for maint. SORRY
Jun 06, 2014 | Samsung WF328AA Front Load Washer
Tip
I bought the original Neptune front load. My wife and two girls have been...
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
on Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire Gallary front load washer: Starts then stops and all lights go out.
Sounds like you are possibly tripping the breaker or have a power issue with the control board in the unit. Contact a professional.
Jul 17, 2012 | Frigidaire GLTF2940ES Front Load Washer
Replace drum bearings on hotpoint aquarius wf000g
You really don't want to know how but here it is. The bearing is located in the rear shell and is not removable the rear shell has to be replaced which means removing the tub assembly from the machine and completely disassembling. With 30 years of appliance repair the last one I did took about 3 hours.
Feb 25, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint waser on/off light flashing and mini load
On mine it was the pressure sensor. remove the top cover and its clipped to the side of the washer behind the soap tray. it has a clear plastic pipe about 1/4inch diamater connected to it.
Took it off gave it a **** and a blow and hey presto, Wifes pi**ed off though, thought she was getting a new machine for a minute. told it's good for at least another five years. We'll see.
Oct 18, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Kenmore 110.22832100 makes clicking noise
it sounds like ur coupler there are 2 screws on ur control panel remove them flip it up remove the shell clips on each corner remove shell down in the front of the unit behind the pump and motor is the coupler 4 clips total 2 remove pump and motor 4 dollar part 3 pcs hope this helps
Dec 29, 2008 | Kenmore 22422 Top Load Washer
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Tub spins too fast on all cylces
Just wondering: did the technician also replace the motor control unit? Or is that the 'spin unit' that you mentioned?
See pages 4-7 and 5-4 in the repair manual.
http://adcxns1.whirlpool.com/Service...0Job%20Aid.pdf
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Neptune-is water supposed to remain, after wash is finished, between tub and outer shell
if you hear water when you spin the basket,that is the front tub balance ring.it is filled halfway with water in order to assist mach in balancing load.that is a normal sound.the mach may also leave some water between the basket and outer shell depending on lengh of drain hose.as long as the clothes do not come in contact with the water it is fine.
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
109 people viewed this question
Top Washing Machines Experts
