Question about Nintendo Wii Console
Input We cannot get the "input" right so the game will show on the TV. HELP!!
  • 4 Answers
You need to make sure that when the game is switched on, that you select either AV or Ext 1 on your remote. I would suggest looking up your TV model manual on the internet. Hope that helps.
Posted on Apr 29, 2008
  • 53 Answers
Mmmmm
Posted on Apr 26, 2008
I found my old N64 console, I only have a rf cable with it but when everything is plugged in i cannot find the channel. My TV is quite old. People say it's 3/4 but i try these and it didn't...
Nintendo 64 AV to TV Hookup
Important Note:
We highly recommend you review the following precautions before you set up and operate your Nintendo system:
Important Safety Warnings & Precautions
Hardware Precautions / Maintenance
Game Pak Precautions / Maintenance
Precautions Concerning TV Screen Damage (Image Retention)
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo A/V cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting the each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo A/V cable into the "multi-out" connector on the back of the Control Deck.
After system is connected to the TV:
Insert Game Pak fully into the Control Deck.
Plug the Controller(s) into the front of the system using the left most port for Player 1.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It's often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You're ready to play!
If after following these directions completely you are not able to view the game, try our Troubleshooting Tips.
Dec 26, 2012 | Nintendo 64 Console
My n 64 has audio but no video
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Dec 25, 2012 | Nintendo 64 Console
This is probably very simple but I'm having trouble: How do I access my PS2 on my Toshiba tv? I've tried all the different inputs but I can't seem to get the game to show up on the televis
Make certain that you have the audio\video plugs in the right holes. Take note of where you plugged the cables in at, there should be a label like "aux input3" or something similar. After ensuring the cables are in their right place turn the PS2 on and navigate to the aux input.
Feb 10, 2012 | Toshiba Televison & Video
I jus bought a new hdmi for my tv and ps3 it plugged evrything in correctly into the right sockets of both the television and ps3 and still nothing shows up and the tv just reads" no input powering...
It is possible that the TV is set to the wrong input, it will not automatically change to the HDMI input. Press the "Input" button on the TV or remote until it is on HDMI.
If that does not word, the HDMI cable is bad, you will need to return it and purchase a new one.
Aug 17, 2011 | Video Game Consoles & Games
My xbox 360 does not show video
Jul 12, 2011 | Microsoft Xbox 360 Console
With the PS2 Slim, when I start the system there just appears a black screen. No configuration menu or gameplay shows up. Whether a game is in the system or not, the problem persists. I need help.
It sounds like the video/audio input on the console is either not plugged in, the TV isn't set to the right input, or the input is malfunctioning. I'd try making sure all of the connections are plugged in securely on both the system and the TV, and cycling through all of your TV's inputs.
Mar 17, 2011 | Sony PlayStation 2 (PS2) Console
My ps3 is connected correectly to the tv but for some reason no picture is showing. It does come on and i have tried another ps3 to make sure everything is connected properly. HELP!!!!!
Try to find the right input ot the cable that your using. If your using HDMi cable then use the HDMI input of your tv, If your using Component Cable look for component input use the original remote of your tv and look for the right input.
Thanks for using Fixya
Jan 24, 2011 | Video Game Consoles & Games
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
Nothing happens
is it on the right input channel? either there will be input 1,2 and some times input 3 try cycling through the inputs with the n64 on by pressing the input button on your TV remote
Aug 18, 2009 | Atlus GBA Game Shark for Nintendo 64
Game mode
yes u can go to the menus and go to input then game mode
Dec 29, 2007 | Sylvania 6419TA 19" TV
Nintendo Wii Console Logo
29 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
