Ms Pacman/Galaga Cocktail Arcade//side 2 not working
I have the Ms Pacman/Galaga Cocktail Arcade Cabinet. How do I get the 2nd side to work. Player 2's turn plays on the player 1 side. So basically, side 2 doesn't play at all.
Re: Ms Pacman/Galaga Cocktail Arcade//side 2 not working
1.Check the dip switches for cocktail set up/ no upright.
2.does the screen flip to the player 2? if yes
3.make sure you have good dc ground in player 2 joystick.
4.if no picture flip for player 2, go to solution 1.
Thank You.
Hello: stuck switch means, a microswitch from the joysticks or
push bottoms or the coin door switch, check 1 by 1 manualy
if you don't hear a click after you push it, that switch is stuck.
Good luck...
Miguel.
Hello: first thing is check the 5V+ 12V+ -5V in the power
supply, sometimes when the power supply goes low or
high cause that problem, other thing that you need check
is the connector for the logic, sometimes contacts get
black, use a eraser to clean the contacts, the last thing
is reseat all chips in the logic, the ones that are in sockets
Thank You..
Miguel
IF you can "play" the game blind, that shows the game board is working fine.
The issue can be in the monitor. That can be many reasons there is no picture .Check all plugs and connectors. Make sure the back of the CT is plugged in. Power to the monitor is present. Do you have amanual for the arcade? You should be able to find one online.
Do you see the picture tube lit up, not on the screen, but in the back of the neck of the tube? (Orange glow from the filament)
I"d suggest that you seek out a qualified service person for the game, if you are not familiar with working on electronics.
There are fuses in the cabinet power supply I believe, check those. Could be something as simple as the fuse going to the monitor.
Use the joystick controller's right and left to select options, and then use either one of the buttons to make your selection. The button with 1 human stick figure next to it is the Player 1 button, and the one with two stick figures is the Player 2 button. Unless the defaults were changed on that machine, 1 quarter is required for 1 player and 2 quarters are required for two players. I haven't used one of these machines since the original from 1982 to 1986. I can't believe it, but Namco actually has put a PDF of the service manual for this unit on their website: http://www.namcoamerica.com/games/pacman/downloads/ms%20pacman%20galaga%20cocktail.pdf
Have fun! I would love to have one of these on day.
