Question about Bosch Axxis WFL 2060 Front Load Washer
Clicking no spinning
Washer clicks and does not spin
Check the capacitor that is used for the induction motor starting .
It is labelled about 16 uF and 350 Vac. ( or similar values)
verify the capacitance if it falls below 20% replace the capacitor.
Posted on May 07, 2008
SOURCE: Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Posted on Apr 19, 2007
SOURCE: clicking noise
Motor brushes
Posted on Jul 11, 2007
SOURCE: washer won't spin
Help
Posted on Aug 20, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Posted on Dec 21, 2008
  • 1937 Answers
SOURCE: Have a Kenmore series 90 washer. During spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers. They describe what happens in the transmission when the washer goes into spin mode:
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Also see the Whirlpool Parts list for their Commercial washers, although the consumer models use the same transmission.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Basically whats happening is this.
When the washer goes into spin mode two plastic cams are forced together and raise a gear on the main agitator shaft that is supposed to keep the agitators from spinning. In actuality, the agitator will still spin somewhat due to the oil moving the shaft.
If the cams are worn (not necessarily broken) the gear doesn't lift high enough to completely disengage the agitators (about 1/16"). We had the same problem. Ours was a major gear noise but a clicking could also be a symptom.
A set of Whirlpool Agitate Cams (part number 62580/01) cost about $15.00.
It's a bit messy to fix (16 oz. of oil in the transmission) but very inexpensive.
See the following for how to remove the transmission.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You don't have to remove the drum.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft, remove the 8 screws carefully the transmission holds 15 Oz of 80-90 weight gear oil. (Available at auto parts stores)
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
I'd also check the Motor Coupler (a $15.00 item that tends to wear) while you have the transmission out.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Posted on Apr 09, 2010
Amana nfw7200 washer clicking noise in spin cycle. still works. faint click if manually spin tub
check spin drum may be some thing in hole or bearing making clicking sound
Feb 08, 2017 | Amana Washing Machines
Will not spin and gives a grinding sound.
could be a problem with the basket drive tube or drive block
Feb 27, 2010 | Kenmore Washing Machines
What makes the washer spin out, this one will not spin
If it agitates but doesn't spin, it is probably the lid switch. Check to see if you get a click when opening and closing the lid to the washer. If you get the click, it might still be bad. If you don't get the click, it can be bad or the finger that depresses the switch is out of adjustment or broken.
Sep 06, 2009 | Kenmore 24032\24036 Top Load Washer
Spin no longer works.
check coupler sounds like it is broken,it is located between the motor and transmission.
Aug 24, 2009 | Whirlpool WTW5300SQ Top Load Washer
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer will not spin just clicks
you must have a faulty transmission or spin tube I could check the top of the spin tube..let me know if you want to go into it..
Aug 31, 2008 | Washing Machines
Loud increasing "ticks" during spin cycle
take the two screws out of the front bottom panel and fill the machine up with water then get a flashlight and turn to spin and if you look at the top of the transmission behind the motor watch for any water flying out it there is that is the cause of the problem if not you have a bad motor
Jan 27, 2008 | Amana NAV5800A Top Load Washer
Amana spin cycle
it sound like the motor is bad,
Dec 31, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch Axxis WFL 2060 Front Load Washer Logo
190 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
