Question about Proscan 32LB30QD 32 in. LCD TV
My proscan 32LB30QD won't power up. It worked
My proscan 32LB30QD won't power up. It worked fine from January to April and won't turn on any more.
    New Friend:
I have the same prob but the red light is on it has done this a few times before and we went back later and tried and it came right on now the red light comes on but we have waited and this time it is not coming on. I am a computer tech if I knew how to get it apart without breaking the case I could fix it . Does anyone have a pic of how it comes apart. Thanks Norman
Posted on Jun 14, 2012
    Guru:
  • 178 Answers
Try this first:
Setup and Connection
The TV won't turn on Check your power cable connection.
• t can't view the Basic channels. Check the connection of the antenna cable
• t want to view cable channels. Register with your local cable company then connect their receiver to your TV.
• t want to view satellite channels. Setup your Satellite parabola antenna then connect your satellite receiver to the TV.
• Digital broadcasting is not functioning Check your antenna cable connection. Check if the digital channel selection is correctly
connected to your antenna cable.
Posted on Jun 15, 2010
SOURCE:
I have a proscan model # 32LB30QD it was manufactured in 2008-10-11. I can watch picture just fine but audio only comes out trough the yellow red white chords. not directly from the tv itself. Sad that i...
Without getting too technical, it sounds like you may have an internal connection issue. Have you tried using external speakers with it? That might be ab easy fix.
Nov 28, 2013 | Proscan 32LB30QD 32 in. LCD TV
Proscan tv
There should be a short circuit to any of its internal board. If power supply switches on, and TV do not work, check the main digital board for fault. Try this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help.
May 20, 2013 | Proscan 32LB30QD 32 in. LCD TV
Proscan 32LB30QD Color Problem
Try resetting it to factory settings and see what the color looks like.
Nov 20, 2011 | Proscan 32LB30QD 32 in. LCD TV
I only need a manual for proscan tv model 32lb30qd, please help me.
Let me know your email address to send you user manual copy of Proscan 32LB30QD tv in your email box. I have this manual copy.
Thanks.
Nov 05, 2010 | Proscan 32LB30QD 32 in. LCD TV
Proscan 32LB30QD. Yesterday it was OK. This
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts:
Please post back what you find
Dec 23, 2009 | Proscan 32LB30QD 32 in. LCD TV
Wall mount screws don't fit in my proscan 32lb30qd
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
Dec 18, 2009 | Proscan 32LB30QD 32 in. LCD TV
Hi, I just bougth a 32'' model # 32LB30QD proscan tv, but I need the codes to play this tv with a direct tv, remot control,,
ok so buy a remote control if you already have one and lost the book search it up on google,dogpile or the companys website
thanx i hope it worked
Sep 17, 2009 | Proscan 32LB30QD 32 in. LCD TV
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
Proscan 32LB30QD 32 in. LCD TV Logo
495 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
