Question about Jensen VM9510 Car DVD Player
DVD player dont know were install the pink cable
    Problem Solver:
  • 5 Answers
The code is a permanent way of disabling the brake override on the jensen units.
There are two ways of doing this:
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
It may take a few tries but you'll get it. This method can be done if you don't want to bother temporarily activating the brake sequence, but if you only have the unit and no additional tv's, its #$%^&* damn hardbecause you can't see the settings your changing.
I tried to make this as clear as possible. If you have questions, private message me or post here.
This code DOES work.
Best of Luck!
By the way, this is for informational purposes only and I will not be responsible for anything bad/stupid/ignorant you do with your Jensen unit.
Posted on Apr 23, 2008
I would like to install this into my 2002 Ford Explorer
You need the Metra 70-1771 Receiver Wiring Harness. You can enter this wiring harness under google search then select the web shopping option. Or you can copy and paste this link:
IF you google it under shopping remember you will find same item for lower cost. Your choice
most people dont know this but the brake cable from the DVD player usually its pink, you tie it together with the vehicles black ground cable. This will allow you to use the DVD player while driving. (remember though its considered illegal in CA. I only let you know for informational purposes. Hope it helped
Carlos Q.
Mar 10, 2015 | Pioneer AVH-P5200DVD 7 in. Car DVD Player
Dvd color mostly blue and pink, colors look weird
try connecting thru an hdmi cable from your dvd player to your tv, check the colors then.. I'd say you have crossed your component cables.. match the connector letters a/b/x? and plug them in one after each other.
Nov 05, 2007 | Konka KDL-37AT23U Television
My Sharp Aquos BD-24 Disc Player has been working awesome (for all my dvd's, including bluray) since I first installed it over a year ago. This week I've tried 3-4 dvd's including bluray and the picture...
Its highly likely a cable issue. You know which cable connection is wrong if are using component in and out. But change to a new connection cable whatever it is and I think it will be solved
Mar 08, 2014 | Sharp AQUOS Blu-ray Disc Player
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
My dvd player is a boss 9800b i can't see the image when the dvd disc is playing , on the screen there's a message ''parking'' the pink wire is parking, my car is a hyundai ,
the pink wire is to connect to the negative side of your park brake switch. if you dont know where it is see a licenced installer. hope this helps let me know how you get on.
Jan 26, 2011 | Boss DVD9800B Car DVD Player
Its illegal to watch a dvd/tv when the vehicle is moving so the manufacturer disables the function.. Usually by connecting a cable to your handbrake indicator or to your vehicle speed sensor VSS.
Youll have to find out which one it is. You can then find out how to disable it. JVC's normally ground the H/brake cable
Apr 04, 2008 | Power Acoustik PTID-900 Car DVD Player
Phase linear uv8 parking brake problem
for the uv8 to bypass the parking brake to watch dvds you have to take the pink wire and put one end to one of the screws on a two screw toggle switch connect the other end of the pink wire to the other screw and connect that to the black ground wire
Mar 12, 2008 | Phase Linear UDV9010 Car DVD Player
Jensen uv8 help
The green with white is for the back up camera option, if you dont have a camera dont hook it up. If you use th remote when in the dvd mode press setup on the remote, then enter 5 4 3 2 1 0 (with the numbered keys) then holding 0 for 4 seconds, this will take you into a screen where you can shut off the parking brake overide. Now you dont have to hook up the pink wire.
Nov 25, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
99 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
