Question about HP LaserJet 2840 All-In-One Printer
50.2 Fuser Error
This error comes up only when i try to print and i can still scan but not letting me print... What do i do please help!!
  • Anonymous May 03, 2008
    yes this is problem
  • Anonymous Jun 03, 2008
    yes
  • 3 Answers
I had the same problem a few months ago. After trying to pull out and reseat the fuser a few times (I would even get one or two prints out of it, in between), I finally ordered another fuser and problem has gone away. I did google and purchsing site searches (pricegrabber, pricewatch, etc) and found a decent priced site, that also gave discount for your returned bad unit (they gave you so many days to return it).
Posted on Jul 04, 2008
    Problem Solver:
  • 5 Answers
Try to reinstall fuser ***'y, located in the back of the printer.
Whem this not solve you're problem you've to change the fuser ***'y.
p.n. RG5-7602 110-127 VOLT or RG5-7603 220-240 VOLT
Posted on May 14, 2008
My dell 5210 is showing a 920.16 Service Fuser Error. How I fix this/trouble shoot?
920 Fuser Error indicates the Fuser is below temperature while printing. The fuser, melts or fuses the toner to the media and has a heat roller and a pressure roller. The heated roller is heated by a halogen lamp or in some cases a solid state ceramic heating element and is subject to failure.
If this is the first time you have seen the error
    1. Power the printer off.
    2. Leave the printer powered off for 20 to 30 seconds.
    3. Power the printer back on. If it comes up to the Ready state, try printing again.
      • If the fuser error does not return, continue using the printer as normal but observe it closely over the next few days to see if the error returns.
      • If the fuser error returns on power-up or if the error returns as soon as you try to print or at a later date, the printer will probably require service to correct the issue.
  1. One thing that you can check as well (since it is a "under temperature" error), is to make sure the printer is not plugged in to a UPS/surge protector. The printer may not be getting enough electricity to heat up the fuser. Try plugin it in to directly to the wall/different outlet and see if the error persists.
If this does not correct it, you need to replace the fuser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Office Equipment & Supplies
I had a problem in the printer saying that 50.2 fuser error that i can neither print, nor xerox & nor scan also. what can i do now?
When a 50.x fuser appear its because the fuser its worn, its probably overheating. I can suggest to take it out (in the back you will see 2 blue locks) for about half hour (turn the unit off before you are doing that) and put it back in. If the error persist you need a new fuser. Good luck
Sep 06, 2010 | HP LaserJet 2840 All-In-One Printer
Lexmark X5150 All-in-One Error: 50
"When the printer fuser fails it prompts many HP laser printers to display an ERROR CODE 50 service code" same could be said about the lexmark fuser malfunction
replacining a fuser can be expensive might be better to get another printer unless you have a special bond like me i find it hard to just throw away things that have gone bad
Feb 01, 2010 | Lexmark X5150 All-In-One InkJet Printer
What does 50.2 fuser error mean
The 50.2 error means your fuser is not heating up. You will need to order either just the fuser HP Part # RG5-7060 or the maintenance kit HP part # Q1860-69002. Check your local computer store or we can ship the parts to you. If you need additional information contact me at our web site below.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 17, 2009 | HP LaserJet 5100tn Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
50 service flashing on display screen
If the display panel reads 50 FUSER ERROR, CYCLE POWER, turn the printer off for 15 minutes. This allows the capacitor that is responsible for signaling this error to discharge. If you don't wait 15 minutes you will continue to get this error even if you have replaced the fuser. If it continues to show the error, then you need to replace the fuser. It is easy to replace.
The fuser maintenance kit is about $119. on the web.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 17, 2008 | HP LaserJet 4 plus Printer
HP Laser Jet 2840 50.2 Fuser Error
Usually this means that the fuser is not heating to the correct operating temperature. Remove the fuser and check all contacts. Be careful it can be very hot. Always let it cool down for atleast 30 minutes before touching the face of the fuser. After you check it over and clean off any contacts, reseat the fuser back into the printer. Plug it back in and turn the printer on. If this doesn't work and you still get the error, the fuser needs to be replaced.
Apr 12, 2008 | HP LaserJet 2840 All-In-One Printer
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
When you print it cimes on 50.1 fuser error and won't print
Your fuser lamp is not coming on. Reseat the fuser. If that does not help, your fuser will need to be replaced.
Mar 03, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2840 All-In-One Printer Logo
119 people viewed this question
Seeker5211
Seeker5211
