Question about HP LaserJet 2840 All-In-One Printer
HP Laser Jet 2840 50.2 Fuser Error
I get this only when i try to print something. I can still scan but not print what do i do?? Please help!!
Usually this means that the fuser is not heating to the correct operating temperature. Remove the fuser and check all contacts. Be careful it can be very hot. Always let it cool down for atleast 30 minutes before touching the face of the fuser. After you check it over and clean off any contacts, reseat the fuser back into the printer. Plug it back in and turn the printer on. If this doesn't work and you still get the error, the fuser needs to be replaced.
Posted on Oct 09, 2009
3 Suggested Answers
  • 327 Answers
SOURCE: hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
Posted on Dec 15, 2008
  • 217 Answers
SOURCE: the hp color laser jet 2840 does not print.
As the message says, you have a problem with the fusing unit. The only way to solve this problem is replacing it. Gerrit Jan
Posted on Nov 02, 2009
Each time I try to print envelopes on the HP Color Laser Jet CP3505x printer, I am gettig a Fuser 50.2 error message
It's unfortunate Janice but your fuser cannot get hot enough to print on an envelope and the only thing you can do is buy another fuser... sounds like the fuser is still able to heat up enough for regular prints on regular paper so you may want to keep it around for a spare but companies usually sell cheaper when you have a core to return to them... Click Here for Fuser
Oct 03, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Hp laser jet 2420 printer 50. error
This is an error with your fuser...you need another fuser...any 50.x error is related to that and they are something that needs replacing regularly(100-150k pages) the heat resister goes out or the film tears..ect....Try www.getthatpart.com for a good deal on a used one...Used are normally just as good as new for a lot less and these guys guarantee their units, they have someone you can call on the phone, so I recommend them. Hope this helps you.
Oct 25, 2010 | HP LaserJet 2420dn Printer
Hi i have a hp laser jet p2015n, error lights
while all lights lit press go button and check secondary light pattern probably scanner if you have tried all parts listed
Jul 30, 2010 | HP LaserJet P2015n Printer
Hp 4250 laser jet vertical streak ghost image
The problem you are having is caused by the fuser. The fuser is the part in the printer that heats up and basically melts ( fuses) the toner to the page. The fuser has a heat roller that is coated with teflon, your fuser coating has worn off in spots so the toner is sticking to the roller and causing the ghost image. You will need to order a replacement fuser. You can do a search on Google to find a replacement, the parts number is RM1-1082.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 04, 2010 | HP LaserJet 4250 Printer
I have HP Laser Jet 1020 When I print letters
Most cases on that machine it's the transfer roller that does that at 75mm, but could also be drum cartridge or fuser. Use a flashlight and inspect the fuser, shouldn't be toner or image on fuser rollers, If you unplug the machine when the print is in the middle, you can tell if it's before or after the fuser, and after the drum.
Nov 24, 2009 | HP LaserJet 1020 Printer
Unable to print or scan - copy only
that is a networking problem the fact the you can copy eliminates the possibility that there is something wrong with the printer / copier
Mar 25, 2009 | HP Office Equipment & Supplies
When you print it cimes on 50.1 fuser error and won't print
Your fuser lamp is not coming on. Reseat the fuser. If that does not help, your fuser will need to be replaced.
Mar 03, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2840 All-In-One Printer Logo
869 people viewed this question
Seeker5211
Seeker5211
