Question about Philips GoGear HDD6330 MP3 Player
Phillips Go gear trouble
Well. i was at school going to turnoff my Gogear and i noticed it was frozen so i put it in my back hoping it would turn off normally i got home still not off so i tried to drain it next thing i know i didnt train i asked forhelp a friend told me this site we did exactly what it told me too i let it charge for about 2 hours now the screen isnt even lighting up Can someone enlighten me on what to do cuz im so pissed off at it right now feel like chucking it out my window =)
  • 3 Answers
Sorry dominik i cant help you. im trying to fix it right now but it wont do anything.
Sorry Bud, PIotR
Posted on Apr 14, 2008
My philips go gear mp3 player 8gb SA52XX is frozen (stuck at the part where it says go gear) nd due to that my pc ownt recognize it and nd obviously i cant listen ot music, iv tried everythiing frm...
Hi Ayesha. Resetting the device should be able to fix minor problem with the unit. Since resetting the device had no effect, the problem you might encountering there is more of firmware problem. Try to reinstall/upgrade the firmware of your device. Philips has software that is called SONGBIRD. I think you have that one in the cd when you purchased the program You may download the progra,m by clicking here. Below is the procedure on how to perform the uprgade:
Download and install the Phillips Songbird program. Launch the Phillips Songbird software.
Connect the Phillips GoGear MP3 player to your computer using the supplied USB cable. Click the icon of your GoGear MP3 player on the left side of the Songbird interface.
Click the "Tools" tab. Click the "Check for updated firmware" button. If a new update is available for your device, it will be downloaded and applied. Do not disconnect the GoGear MP3 player until the Songbird program tells you that the installation is complete.
Hope this helps..
Jul 18, 2011 | Philips GoGear HDD1830 MP3 Player
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
Philips gogear vibe will not open music folder
HAve you tried resetting the go gear when the fault came in, if not try to reset the go gear. There is a tiny hole on the go gear, use an office pin to push and hold for few seconds to reset,Now the set must work fine. If not connect your gogear to the PC and do a scan for virus or corrupt programmes installed. If so delete, save the listed programmes to the PC and reinstall them back. Use the media convertor software provided when you are converting media files on the go gear or else it will not read or access. Hope the advice helps you. Good day
Jul 14, 2010 | Philips Electronics - Others
I have a Phillips GoGear Mix 4GB frozen.........
I had a frozen screen too just five minutes ago. I thought it was completely broken until I realised there was a reset button on the side of the mp3 ^^ Hope this helps
Apr 10, 2010 | Philips Audio Players & Recorders
What video format does gogear vibe use?
my mp3/4 does not play video when you click on vidio it says video format not supported
Jun 29, 2009 | Philips GOGEAR SA6045 MP3 Player
Can't put videos on my Phillips go gear (8gb) mp3 player
Did you install in your computer the Phillips media converter? If not that would be your problem. Hoped I helped.
Apr 25, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips Gogear SA5285/37 is frozen
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 08, 2009 | Philips GoGear SA5285/37 Digital Media...
Phillips gogear is frozen
Press and hold the Power On/Off key and the Volume + key for a couple of seconds to reset
If that alone fails, run a Repair in the Philips Device Manager
-Tha Mp3 Doctor
Dec 27, 2008 | Philips GoGear HDD6330 MP3 Player
Frozen solid
i have the same promblem i was listening to my music and it had full batteries and it just shut off this is so bull like i think i have to return it and buy something else!!
May 06, 2008 | Philips GOGEAR SA6045 MP3 Player
Go Gear Trouble
Try this:
Make sure the GoGear is disconnected from the computer
Turn the goGear off
Reconnect the goGear to the computer while holding in the volume + button
Continue holding the volume + button for 20-30 seconds until a "Found New Hardware Wizard" window pops up
If this does not work, the GoGear is toast, call 1-888-PHILIPS and see if you are still in warranty
Apr 13, 2008 | Philips GoGear HDD6330 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
41 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
