Question about Casio G-SHOCK 200M DW5600E1V Wrist Watch
Hi I have a casio g-shock DW9400 and I lost some small springs inside when I tried to change the baterry. Where can I get some help for this? I live in Montreal Thx Dan
I too lost the spring-
ive just got it working by basically using half a staple bent so it contacts the back plate-
works fine.
hope this helps
Posted on Jul 03, 2008
Casio GW810D I have changed the battery, the display is now running but none of the buttons are functioning. Have I missed/lost something. Any help is appreciated.
you need to do this Shortcut the battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs
Feb 12, 2013 | Casio GW810D 1 Digital Shock Watch
Found small spring when changing battery
This happened because the COIL SPRING was lost during the battery change. This happens quite often to DIYers, as they do not know how the watch is built and the coil spring itself is very small, so, it's easy to loose it without even noticing it. Coil spring transmits electrical signals/vibrations from watch's movement to the quartz membrane attached inside case back. Now you have to find yours or need to visit your nearest watch repair shop and ask for the new one to be fitted..
Oct 18, 2012 | Casio Watches
Hi. i cant change the time on my casio g-1000. the reason for this is i have lost my manual. can you help?
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Mar 30, 2011 | Casio G1000 1A G Shock 5 Motor Chronograph...
I have a casio g-shock G7700-1 i cant change the time
Here is the manual
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=3095
Mar 30, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
I have a casio g shock and i lost the manual
go to www.gshock.com scroll to bottom of page click support find manuals tab it will need a module # which is located on the back of your wath just above the casio name it's 4 #"S inside an outline and then print
Nov 02, 2008 | Watches
Lost alarm & all Beeps on Casio G-Shock G3110 Wristwatch
You probibly lost a little spring that goes into your movement that makes contact the curcit board and the back of your watch. It is VERY small and alot of people who change their own batteries don't even see it when they open their watch and it falla out . If I knew your address I would send you a couple. If you look at the back of yhe inside of your watch you will probibly see a hole with a LITTLE straight line comming off of it, that is where that spring goes. NOW you MAY not have grounded your watch, that could cause that to happen to. Open your watch and look at the back. You should see a AC marking. Take a tweezer or a metal object and touch the ac and the top of the battery.Then re-set your watch time. I'm hoping that is it, if not you need that spring.Let me know what happens, and if I can assit you with any other watch or jewelry problem.Also we at home are proud of you!!! Good Luck!!!
Jul 09, 2008 | Casio G-Shock G3110-1V Wrist Watch
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio g-shock watch
Unfortunately I am not familiar with this watch, you should try this page to find a manual for it: http://world.casio.com/wat/download/en/manual/ If not contact Casio costumer support Good luck Daniel
Sep 05, 2007 | Casio G-Shock G510D-1AV Wrist Watch
Casio G-SHOCK 200M DW5600E1V Wrist Watch Logo
209 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
