Question about Cooktops
Frigidaire PLES389ECC Door won't stay closed
I have the Frigidaire PLES389ECC slide-In glass top oven. It is about 1.5 years old. Upon heating the oven the door begins to open slightly. The light in the oven will eventually come on as the switch is near the point of full extension and contact is made and the light comes on. It is almost like the gasket expands as you can look at the door from the side and see the slight angle that is formed between the oven frame and the door's edge. The best I can guess is the gasket is expanding. Should the door gasket expand to the point that it causes this?? I just don't know what to do!
Thanks,
Bob
  • larry jaxson Apr 13, 2008
    WELL,
    Problem solved. The metal part that covers/hides the lower element in the oven was shifted forward about 1/4-1/2 inch and prevented that door from completely closing. I shifted the cover back and it seemed to fit a little better and then I tested the door. It was visibly hard to tell that the door was opened any more no matter where the metal part was in the bottom of the oven, however heating the oven proved that my moving it was THE solution.
    Bob
    Genius:
  • 1,073 Answers
Great fix
Posted on Apr 13, 2008
My elements are off but the red light is still on?
Red light will stay on until burner temperature is down to a safe level.
Oct 02, 2016 | Frigidaire Stove/Oven/Range Black Glass...
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
My stove top works but oven and broiler will not heat
Good Afternoon friend, thanks for your post!
I see that your oven and broiler will not work on your Frigidaire range. It could be possible that your elements are bad or the thermostat may have shorted. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to have a professional technician come out to pinpoint the issue within your range. Best of luck! -Matt
Feb 16, 2015 | Frigidaire Stove / Oven / Range Glass...
Oven door dirty between glasses
Usually there is a spot right before close that the door wool slip off the hinge. On some models you use a nail to hold it on place some have a special hinge. After that the door comes off and a few access gives you access to the inside panel
Sep 13, 2014 | Maytag MES5752BAW Slide In Electric Range
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Frigidaire Gallery Microware door doesn't latch
I experienced the same problem. The solution was easy, for me at least. Remove the door. pry loose the plastic liner that covers the inside of door. remove the four screws that hold the glass unit in place. You will find rattling around inside a spring about an inch long and a broken plastic piece about an inch and a half tall. On my unit the plastic piece was still hanging on by a thread which gave me a clear understanding of how the door latch is supposed to work. Remove the plastic latch unit which is designed to slide on the two posts about three eights of on inch distance under the pressure of the spring. Problem is loss of spring induced pressure.
The repair: ( I used my bandsaw to do this) fashion a piece of wood with indentations that correspond to the plastic ribs enabling the wood to sit perfectly into the space. Drill a hole at the point where the inch and a half "anchor post" broke off and insert a dowel of same length. I carved a shallow indentation for the spring, pressed the spring on with needle nose pliers, replaced the sliding latch mechanism, attached other end of spring to the latch. I drilled into the exterior plastic door frame and installed a flat head screw to hold the wood repair piece solidly in place. Re-install pieces removed earlier and you have a happy, functioning Frigidaire gallery micro at your service. Took an hour.
Apr 06, 2014 | Frigidaire Gallery FGMV174KF 1.7 cu. ft....
Light stays on in De Dietrich oven DOD438 all the time. It is in the lower oven. Stays on whether door is open or closed. Oven is new since May 2007
I too have just had this problem. The door switch (top right corner) is broken and the oven thinks the door is always open. Chances are it won't heat up either.
Apr 05, 2010 | De Dietrich 22 in. DTV315 Electric Cooktop
One of my large burner not working
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Sep 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Large section of dual burner not working
Jul 07, 2009 | GE 30 in. Profile JP989 Electric Cooktop
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Cooktops Logo
211 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Gere knutson
Are you a Cooktop Expert? Answer questions, earn points and help others
