Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
I checked all the connections for a loose connection and everything seemed to be as it should. When it came back on the oven and microwave lights functioned. There are three main wires that come in with a copper ground and the all seem to have 110 volts. It that what it is supposed to be. when the display is off everything (connections and plugs) has power. Not every wire of course, but some in every cluster going to the control panel.
    Genius:
  • 1,073 Answers
The black to white 120 the red to white 120 the red to black 240 the bare copper can tie to the white neutral and ground will work as the same any other reading then there is a voltage problem in the house
Posted on Apr 12, 2008
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Can't change light bulb
yes you wilkl need to remov ethe micro from the oven mountingin order to access the light bulb (dumb-design) but no way around it
Nov 16, 2008 | KitchenAid Architect Series KEMC308KSS...
Displaying DOOR
there is two fuses a 15 amp and a 20 amp fuse on the left hand side of the microwave one or both have blown
Jul 08, 2008 | KitchenAid Architect Series KEMC308KSS...
what if we have a voltage problem in the house, then it would be a lot cheaper to have a ceritifed electrician look at this beacuse there has to be a connection that the service man is overlooking than to purchace a new double oven at a tune of 1500.00
clll me 276-523-4434 David
Apr 12, 2008 | KitchenAid Architect Series KEMC308KSS...
check your power connections at the junction box, the unit for the clock is only pulling an amp at the most, but when you try to use the ove your putting the electrial connections under a load and if not tight or right will cut off the display and main cpu unit
there is a loose connection somewhere
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
120 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
