Question about Sewing Machines
EURO PRO 6131 Sewing Machine not maintaining stitch
I have a EUROPRO 6131 Sewing Machine it was sewing fine, then it stopped picking up the bobbin thread. I then oiled it and cleaned it (it was full of wool fibers) and rethreaded it several times, put in new needles, different size needles etc. and it starts out and usually makes a couple of stitches and then the tread is just a straight line on either side of the fabric. The needle is inserted right. The bobbin is installed right, but after a couple of stitches usually about exactly 6 stitches at best the upper and lower thread is not hooked together, running on the settings that use to sew just dandy? Can you please suggest what I might do? Is it a timing issue? The machine was rather dirty with heavy wool (18.5 oz) and before this happened I was having a problem with feed with heavy seams, where the needle was sewing in one place for too long and kinda growing a beard under the needle plate that snagged the material in place, and stopping it, so that I had to cut the beard off and start anew to start sewing again, but now it won't make too many secure stitchs no matter what the material thickess or overlap, usually about exactly 6 stitches good stitches and that's it.
Thanks ohallock@yahoo.com
I have a Euro-pro model 6131 sewing machine.I just oiled and cleaned it. I am trying to find the standard factory settings i.e stitch length, stitch width, tension, and stitch setting, etc.
The only factory standard settings that you need to worry about is the top tension and the bobbin tension. The standard factory top tension is the midway point between high & low numbers. That is the ideal tension setting for most fabrics, thread, and needles. However, that is also adjusted based on what you are sewing. Bobbin tension you should leave as is unless there are issues that the top tension will not resolve. The other settings you mention are all adjustable based on what you want to do with your machine, ie straight vs zig-zag stitch, etc.--no standard factory setting.
Nov 25, 2017 | Euro-Pro Sewing Machines
Euro Pro 9105 won't catch bobbin thread
first of all make sure you have the needle in the correct way round, flat side facing back, try a new needle, it only has to be slightly bent or blunt and it will miss stitches, the tension unit is the small piece near the takeup lever and it only has a small spring but that has nothing to do with the threading picking up, if the machine misses stitches after trying the above then you will need to retime the machine either bu a shop or by yourself, if you are sewing on fabric that collects static such as knitted fabric make sure you use an anti-static needle otherwise it will miss stitches.
Goodluck..
May 23, 2008 | Euro-Pro 9105 Computerized Sewing Machine
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
Can you use metal bobbins in this machine?
Probably. Most are plastic today because they're cheaper.
If they fit and work, go ahead.
Here are parts being offered for your machine; 6130 is close to 6131.
Euro Pro 6130A2 Parts
Mar 28, 2015 | Euro-Pro 6131 Mechanical Sewing Machine
Europro model 6131 is stuck in reverse
I have never found any online instruction manuals and repair manuals are just as non-existent.
You can try jiggling the reverse lever while turning the hand wheel. Other than that the only suggestion I have is to use the machine for target practice.
Oct 02, 2012 | Euro-Pro 6131 Mechanical Sewing Machine
Want to use other stitches on my euro-pro model 6131 but dont know how to use the different feet
I have a lot of different sites, free and pay, that I search for manuals for people. But I didn't find a manual for a 6131. I DID find a 6130A and, often, models that are that close in number are very similar in their instructions.
Since the manual is free, it doesn't cost you anything but time to download it and see if it looks similar to your machine. It may give you the information you need on the feet. Go to http://homeappliance.manualsonline.com/manuals/mfg/europro/europro_6130a_lcd.html/ Go to the bottom of the pop up window and just agree to the terms-you don't have to take part in any of the offers or sign up for the sight. You'll then be taken to the manual and can download it without any viruses. The sites been checked before not just by myself but a couple of my friends who are bigger internet geeks than I am :).
I hope this manual gives you the help you need. Happy sewing!
Jun 16, 2011 | Euro-Pro 6131 Mechanical Sewing Machine
Why won't my needle pick up the bobin thread?
the bobbin case may not be in correct position or completely threaded sometimes the thread will slip out of placemment in the bobbin case
Dec 10, 2009 | Euro-Pro 6131 Mechanical Sewing Machine
Bobbin cover plate
click this link directly.http://www.euro-pro.com/europro/categorybrowse.aspx?cat=Sewing(EuroPro) ------------- this is direct link for the service center.you will have to enter the model number and place the order.this will help you.
Sep 16, 2009 | Euro-Pro 373 Mechanical Sewing Machine
Machine won't sew at all
RE: Euro-Pro 9000 Mechanical Sewing Machine "Won't Sew"
I am wondering if you tried unplugging it for at least 1 minute to let it reset the onboard computer (sometimes they need to be unplugged overnight).
Try the following links....
FAQ @ http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
Manual @ http://www.euro-pro.com/europro/manuals/9000.pdf
Customer Service @ http://www.euro-pro.com/europro/feedback.aspx
Let me know if I can assist further!
jackiaria
Feb 28, 2009 | Euro-Pro 9000 Mechanical Sewing Machine
Sewing Machines Logo
239 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
