Question about Whirlpool GU2400XTP Built-in Dishwasher
Led panel does not display full functionality
Many of the led displays only half light, or don't light at all????
    Genius:
  • 1,073 Answers
Replace the control board
Posted on Apr 12, 2008
I have LED 32" problem with display
Back-light inverter board problem. Contact any service technician.
Gopakumar Gopalan Google
Apr 11, 2014 | Televison & Video
Error 5b00
Hello, your error is about the ink absorber.
"Ink absorber full Japan:
[5B00]
Others:
[5B01]
P07 The ink absorber
becomes full.
Replace the ink absorber (ink absorber kit), and
reset the ink absorber counter."
This is the way to enter service mode:
"Start the printer in the service mode.
i. With the machine power turned off, while pressing the Stop/Reset button, press and hold
the ON button. (DO NOT release the buttons).
ii. When the Power LED lights in green, while holding the ON button, release the Stop/Reset
button. (DO NOT release the ON button.)
iii. While holding the ON button, press the Stop/Reset button 5 times, and then release both
the ON and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm
and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm
LED.)
iv. When the Power LED lights in green, the machine is ready for the service mode operation
and "0" is displayed on the 7-segment LCD.
2) Start the Service Tool on the connected computer.
i. When a button is clicked in the Service Tool dialog box, that function is performed. During
operation of the selected function, all the Service Tool buttons are dimmed and inactive.
ii When the operation is completed, "A function was finished." is displayed, and another
function can be selected.
iii If a non-supported function is selected, "Error!" is displayed. Click OK in the error message
dialog box to exit the error."
You can use the service tool to reset this error after you have enter service mode.
here is the service tool:
http://www.4shared.com/file/QptYmQTM/ServiceTool_V1074planet.html?
Nov 03, 2013 | Canon PIXMA MP180 All-In-One InkJet...
I have a herritage t101, it displays the Ls error and has no drive whatsoever but was working a few month back
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP elevation motor. Use the contact cleaner, you can find it in R .Shack.
see the diagram attached.
Jan 14, 2013 | Exercise & Fitness
Display light of HP9250C control panel is not working, how do I troubleshoot it.
Building a simple light-emitting diode (LED) light display can be a great project for both children and adults. A simple LED Display Light can be built using
several LED lights, a resistor and a battery. Once the LED lights are soldered together, they can be mounted in virtually any container or mounted to a board
in a pattern of your choosing.
1.Solder the positive (red) lead of the battery holder to one end of the 1K ohm resistor.
2.Attach the free end of the resistor to the positive lead of the LED. The positive lead of the LED is the longer of the two leads. Solder the negative lead
to the positive lead of the next LED. Continue to wire the LEDs, negative to positive
3.Attach the negative (black) lead of the battery holder to one lead of the push-button switch. Solder the other push-button lead to the negative side of the
last LED.
4.Connect the battery to the battery holder. Activate the push-button switch; the LEDs should light up.
5.Disconnect the battery, if needed, to mount the LEDs to your chosen container.
Sep 08, 2011 | HP 9250c Printer
I have a canon mp 140 multifunctional printer. it shows in its display E8 - ink absorber full. The repair was done cleaning already, but still displays the message E8. What can be done? is there any...
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Mar 27, 2011 | Office Equipment & Supplies
Printer not working.
i. With the printer power turned off, while pressing the Stop button, press and hold the ON
ii. When the Power LED lights in green, while holding the ON button, release the Stop button.
iii. While holding the ON button, press the Stop button 2 times, and then release both the ON
and Stop buttons. (Each time the Stop button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
Without the scanner (connect the operation panel unit.);
While holding the ON button, press the Stop button 3 times, and then release both the
ON and Stop buttons. (Each time the Stop button is pressed, the Alarm and Power
LEDs light alternately, Alarm in orange and Power in green.)
iv. When the Power LED lights in green and "Service Mode Idle" is displayed on the LCD, the
printer is ready for the service mode operation.
(7) Main Main ink absorber counter
resetting
Set a sheet of A4 or Letter sized plain paper. After
the ink absorber counter is reset, the counter value
is printed automatically.
(8) Platen Platen ink absorber
counter resetting
Jul 06, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
Whirlpool GU2400XTP Built-in Dishwasher Logo
77 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
