Question about HP Officejet 7210 All-In-One InkJet Printer
Fix to new number for fix head
Will not change to new fix number
    Problem Solver:
  • 12 Answers
Sounds like there is a hardware problem with the printer
Posted on May 09, 2008
How can I fix no cartridge error on brother mfc-465cn
It sounds like it may actually be the "print head" which is what the carts fit into. These can and will go bad. Sometimes you can find replacements on ebay etc. But you need to make sure it is exactly the same part number. There could also be a number of other issues, the cart contacts could be dirty or damaged (another print head issue resolved by replacing), counterfeit cartridge, bad cart. These are the most common, but not the ONLY issues that can cause your problems. I'd check prices for replacement print head vs. new printer.
Jul 18, 2014 | Brother MFC-465CN InkJet Printer
I have water in my engine oil in my rebuilt saltwater cooled yanmar3GM 30 s after less than 1hr running any ideas will help ,thanks andy
Would be in the head.Either cracked or gasket blown.Take it back and have them fix it right or get your money back....
Aug 17, 2012 | Cars & Trucks
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
I have a Porter Cable framing gun with a constant air stream from the defector. I can't read the model number, but after looking thru the Internet my guess is it's a FR350A. I have used 21 degree...
Air leaking from top of the gun is caused by headvalve orings or trigger valve. Easy fix, remove the head and pop out the headvalve. Remove the orings from headvalve and clean grooves /orings. Reinstall orings and apply plenty of silicone paste lube. If guns holds pressure after cleaning and new silicone paste, order oring kit and have handy when problems start again. If the gun keeps leaking, remove the trigger valve and replace with new or change orings within valve. Good luck
Jun 15, 2011 | Porter Cable Cable No. FC350A Clipped Head...
The triangular fixing socket in the shaver head has split and the rotary head to not stay in place properly. Where can I get a new head frame?
You did not mention your shaver model number so I can not address your specific model. But, you will find many of these type parts a shaveroutlet.com. You will need to know your model number.
Feb 25, 2010 | Remington Health & Beauty
Will not print in black and the colour is sometimes broken up. I have cleaned/deep cleaned as instructed in the manual but problem is still there.
This happens pretty often. Unfortunately it seems you will need service. Sometimes it happens at random, and sometimes it is caused from using generic type ink in the printer instead of Canon ink cartridges. But yes, it could happen even with Canon ink.
What happened is the Print head needs changing, either that or the absorption head, or both. But it does need service. Sometimes they can clean out the head, usually you need a new one.
If the printer is no longer under warranty, it might make more sense to buy a new one instead of fixing yours. Give Canon a call, they will refer you to someone who can fix it and give you an estimate.
I believe the tech support phone number at Canon is:
1-800-828-4040
If it is just the absorber and not the print head, it shouldn't cost very much.
Good luck & happy holidays!
EJ
Dec 28, 2009 | Canon PIXMA iP90 Mobile Printer
Heads destroyed... is it necessary to change controller board ?
Part 1: No (to my knowledge)
Part 2: Test equipment to do that test would be expensive to have for one fix.
Part 3: If you can identify the controller board as being bad, then yes. If you can't identify, then why change it?
After all is said and done, is it worth fixing? I fixed a printer for my office, it took a long time to find the replacement parts, but I got a $600 printer for about $140 in parts and labor... so in this case, it was worth it. Good luck.
Mar 06, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Shaving head check indicator still flashing after installing new heads
Apparently you need to change the heads within two weeks after the red LED first starts to flash, otherwise the memory chip inside needs resetting. This also poses a further question. How does the unit know the heads have been changed or not ?
Jan 12, 2008 | Philips Philishave HQ7780 Electric Shaver
Maintenance Mode
Les,
you dont have to compute any numbers.
Simply change the printhead.
If you receive an error starting with 4 again, this means that the "new" ph is faulty, too.
Save lifetime and energy and buy a new dcp 130 or 135 because this is cheaper.
Jan 04, 2008 | Brother DCP-110C All-In-One InkJet Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
