Question about Bugaboo Frog Stroller
Unfolding the Chassis - Handlebar Loose
I just purchased a Bugaboo Frog. In unfolding the chassis, I follow the instructions below. After I hear the click on both sides, I notice the handlebar can still be moved slightly in the other direction. Does this mean the handlebar is loose or may present a problem? Please advise.
"To unlock the handlebar, pull the two release knobs towards you and lift. Do not press on the handlebar while pulling the knobs. 2 Release the knobs and raise the handlebar to the position shown in Diagram B until you hear a click on both sides."
  • 1 more comment
  • Anonymous Jun 23, 2008
    unlocking the handlebar
  • mckane14 Nov 14, 2008
    i have the same problem the handle bars move slightly back and forth after locked in place.
  • Kalifornia Nov 20, 2008
    Our Frog has broken like this twice. The handlebar is no longer in a firm position after locking, having about 6' of travel in both directions. While pushing you may hear an occasional pop in the internal mechanism as the lock releases, causing the handlebar to unlock.
    The first time this happened the Airline took responsibility and was able to get new parts in about 6 weeks. The second time was about three months ago, and I have not been able to get a Bugaboo Service to call me back.
I had the same problem... the handlebar would 'un-pop' and shake around a lot making the whole stroller unsteady. I started to get all upset and worried about sending it back but i decided to clean it first. After using the silicon spray from the maintenance kit on the joints of the stroller IT WORKS LIKE NEW! yay! Try this before assuming its broken :)
Posted on Mar 02, 2009
    Problem Solver:
  • 19 Answers
If you continue to hold the release knobs toward you, you can reverse the handle bar completely to the other side. If you release the knobs as soon as you hear the click, the handle bars should lock into place, although it isn't as steady as it should be. It could be a little shaky, but shouldn't move the other direction if the release knobs aren't pushed.
Posted on Jun 28, 2008
Can I modify the handle bars on a Frog? I need to lower them for Mum under 5ft tall? Take then off and replace with adjustable handlebar? Which part would I need to purchase? Is it in stock? price?
The Cameleon has the adjustable handle it is not available as a part only as a complete chassis for around $400 www.babycare.nl/bugaboo-cameleon-chassis-p-2466.html. Your Frog wheels, seat etc would fit. If you found a broken Cam frame on eBay you could swap the handles. Your Frog would have the parts required to fix the Cam. Click on this link to my tips section www.fixya.com/support/r7805199-fix_bugaboo_handle_lock. Note as you don't need the old Frog handle you could try prizing off and reusing the domes but I don't recommend that. Brake cable is compatible.
Aug 05, 2011 | Bugaboo Frog - Black Stroller
Will a frog seat frame fit on a cameleon chassis
Yes it will fit. the fabric seats are not interchangeable but everything else is. Currently I have Cam wheels on my frog chassis. As well as a cameleon canopy, and a fabric flease set on my frog seat.
Apr 20, 2010 | Bugaboo Cameleon Stroller
Bugaboo Frog has a loose handle
Theres a company that repairs bugaboo chassis their web site www.buggypitstop.co.uk
Apr 08, 2010 | Bugaboo Frog Stroller
A friend lent me her old Bugaboo Frog. It has been working fine. I am able to remove the seat and fold the chassis into the folded position. When I try to unfold the chassis, I am able to get the...
This should only happen when the seat/carrycot frame has not been put on. If this happens when the seat is on, then I would suggest that this is returned for a repair (www.bugaboo.com) as this could be dangerous.
Hope this helps.
Feb 24, 2010 | Bugaboo Baby Gear
Dont no how to unfold it
To unfold the Frog:
Stand behind the chassis with the handle bar nearest to you.
Bend down (leaving the chassis on the floor - don't try an elevate it at all) hold the handle, push the small white button in on your left hand, once depressed pull both triggers (one either side), this will release the handle.
DONT try and open the chassis just yet!
Lift the handle up and stand upright.
In front of you, you will see two parallel axles (nearly touching the floor) place your foot onto the BOTTOM axle and gently push downwards and then kick it outward away from you.
This should open the chassis.
Once the chassis is open, it will appear to be unstable, this will STOP once the seat OR carrycot are clicked onto the chassis.
I hope that all made sense and helps you.
Faling that, I would suggest that you perhaps contact Bugaboo.com for some advice as this is extremely hard to convey in text - Good Luck!
Aug 10, 2009 | Bugaboo Frog Stroller
My Bugaboo Chameleon bent
The best advice that I can give is to contat Bugaboo (www.bugaboo.com) who will be able to advise on the cost of a replacement chassis. Alternatively, you can purchase these from eBay most of the time.
I hoep this helps.
Apr 14, 2009 | Bugaboo Frog Stroller
Bugaboo chassie
HIYA... THE CHASSIS STAYS FILMSY AND UNSECURE UNTIL THE SEAT UNIT OR CARRYCOT UNIT IS ATTACHED, THEN ITS LOCKED INTO PLACE AND SECURE :)
IT ISNT A FAULT, THIS IS JUST HOW ITS MEANT TO BE
HOPE THIS HELPS X
Mar 13, 2009 | Bugaboo Frog - Black Stroller
Unfolding a pushchair
lay the Frog chassis FLAT on the floor, pull the two release knobs on either side of the handlebar toward you while lifting the handlebar up at the same time.
May 18, 2008 | Baby Gear
Faulty Bugaboo Bee
I to had this problem, my problem was i also lost proof of purchase so couldnt get a new chassis, Bugaboo even though the prams havent been out for two years wouldnt replace so i had to try and either fix the pram or buy a new chassis for £235. I then read on the internet about how to remove the rivets on the chassis, you need a rivet gun and a drill the problem was the rubber had broken and fallen way down the pram chassis and if you can replace this with some new rubber the chassis is good to go (just make sure you do this slowly so you can see what part goes back where), you need to buy new rivets as when you remove the old olds these are no longer useable, i am soo happy i tried to fix this, it took me and my sister 1/2 hour and saved me £235 (the price quoted by Bugaboo for a new chassis). Hey hope this helps anyone and saves you having to line Bugaboo pockets, hey theres a clearly a niche in the market as Bugaboo do not have a work shop, they clearly want you to keep spending!!!!
Mar 22, 2008 | Audio Players & Recorders
Bugaboo Frog
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: service@us.bugaboo.com
WEB SITE: WWW.BUGABOO.COM
Aug 16, 2007 | Bugaboo Frog - Aubergine Stroller
Bugaboo Frog Stroller Logo
1,463 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
