Can i program my remote to change channels through my direct tv box
  • 8,617 Answers
No Direct TVs need their own remotes. You can get a replacement Direct TV remote at the following link they ship for free anywhere in the U.S.
http://servicemanuals.vstore.ca/
Posted on Apr 12, 2008
Charter remote will not change channels--I have put in tv code but still nothing--noting on the remote will work except to power the tv on
You will need to program it to your cable box to change channels. Remember, the channels in your tv are coming from your box, so if the remote can't control the box, you won't be able to change channels. Call charter for help on programming remote to cable box.
Jan 22, 2011 | Televison & Video
Cannot program channels into remote
IF YOU, STILL SUBSCRIBE DIRECTV, YOU MAY GO TO THE MENU, USING THEIR CLICKER AND GO TO THE PART OF MENU, WHERE YOU CAN CHOOSE TV TO OPERATE WITH DIRECTV REMOTE. YOU WON'T BE ABLE TO CHANGE ANYTHING ON TV BY USE DIRECTV REMOTE, BUT TO OPERATE IT'S CONTROL BOX. REALLY, YOU CHANGING CHANNELS ON THAT BOX, NOT TV ITSELF. IF YOU'RE NOT A SUBSCRIBER, FORGET THAT REMOTE! UNLESS YOU'RE A CUSTOMER, IT WON'T HAPPEN. JUST "GOOGLE" YOUR MAKE AND MODEL FOR A SUITABLE UNIVERSAL REMOTE, OR THE ORIGINAL.
ALSO: YOU WON'T BE ABLE TO GET ANY RECEPTION(HD OR ANY), UNLESS YOU HAVE RABBIT EARS OR ANTENNA ON A ROOF.
GOOD LUCK,
ALEX'S TV.
Apr 06, 2010 | Protron PLTV-32 Television
When my sharp lc 32sb220u is turned on, my direct tv remote will not change channels. this just started. Nothig was changed. after this, i did change the direct tv box and it still would not change...
That remote has to work / it is a direct tv issue since it is their equipment that you are renting and it is supposed to work with your set..
Did you make sure that the batteries in the remote are good? that the remote unit itself is good ( Use digital camera or am radio to test out - see google)
Sep 20, 2017 | Sharp Televison & Video
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
My remote control for my polaroid tv wont change channels up and down.the channel button isnt working for the tv.everything else is working.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Apr 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Harmony 880 Logitech won't change channels
Was it working before?  Is it possible you selected the wrong brand of TV when programming the remote?  Do you use a cable box or satellite dish with your TV (in other words, do you change channels by changing the channel on the TV, or on the digital box connected to your TV)?
Mar 30, 2009 | Logitech Harmony 880 Universal Remote...
MY REMOTE WILL NOT CHANGE CHANNELS ONLY TURNS TV ON OR OFF
After much trial and error, we discovered a temporary fix. We taped a 3 x 5 index card to the front of the box directly to the right of the time/ channel number. The remote will change both the channels and the sound level with this "fix." Could there be some kind of emission coming from the box that interferes with the remote? Maybe Motorola could put a more opaque front on the box.
ympm
Jan 11, 2009 | Arris DCT6200 DTV Receiver
32" proscan dual hd tv can't get universal or direct tv remote to work what now
Get a universal from big box and program. If you can find a rca remote, it should be programmed already.
Craig www.classtorations.com
Jun 08, 2008 | Proscan PS32500 32" TV
Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
May 11, 2008 | Logitech Harmony 880 LCD Remote Control
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Televison & Video Logo
Top Televison & Video Experts
