Question about Sony FD Trinitron WEGA KV-13FS100 13" TV
Sony KV-13FS100 - channels cycling
This is a 4 yr old Sony KV-13FS100. The channels on the screeen display cycle through on their own. The reote is inoperative, and the channel buttons on the tv do not work. I have unplugged the set and plugged it back in without resolution. Help
  • mosb Apr 12, 2008
    The remote has no impact on the TV at all. We don't use the remote for this TV.
    The numbers cycle down over and over, but channel itself does not change.
    When I push the volume buttons, the channel does change, but not consistently.
    Unplugging the TV for 1 minute and then plugging it in has no effect.
    It is connected directly to cable (no box).
    I still have the same problem when the cable is disconnected.
  • mosb Apr 12, 2008
    Great, can I buy one of those at Wal-mart?
    Just kidding. I'll take in to the repair center next week. Kind of a PITA though.
I also have a Sony Trinitron model KV-13FS100 (chassis BA6, mfg July 2002) which is experiencing the same problems. I have made the checks suggested by pauldonp above. The channels cycle 1,2,3,4,5 etc. The remote has no effect. The channel up/dwn buttons on the TV have no effect. However when I press volume up or volume down on the TV it stops the channels from cycling for a moment before they continue again. Any help would be greatly appreciated.
Posted on Dec 04, 2008
  • 4,102 Answers
Hi can you try this for me remove battery out of remote for me whilst telly is off then switch telly back on i just want to check their are no buttons stuck on the remote ok post back
Posted on Apr 12, 2008
  • paul proctor Apr 12, 2008
    Also whilst the telly is switched off and unplugged press each button a couple of times on the telly press all of them one at a time press them quick so once pressed you let go quick doing this tells us their are no buttons stuck down ok
    Also are the channels going in order like 1,2,3,4,5 etc or jumping let us know also are they going up or down
  • Sony Master
  • 19,396 Answers
You need to change the control board or the touch buttons
  • Ginko
    Ginko Apr 12, 2008
    Change the control board, it is unlikely the problem is only with the control buttons. In any case check all the buttons contact , in case the problem is just a contact. More likely something on control board is blown , change the whole board.
Sony KV-32FS12. Buttons on the TV don't work, the remote don't work. Now stuck in one channel. Can access Menu with TV button but can't go anywhere. Unplugged from main power source still no go. Tried...
Hello
Your TVs front control buttons are inoperative except menu button. There are microswiches fitted inside the main board of your tv from which shafts ar extented towars the front of the cabin where you press to access the functions. Replace all the micro swiches inside at onetime. It won't cost more. Micro swiches as they have said is mini swiches, which can get damaged easly with high pressure thumb or impact put on it.
Oct 15, 2010 | Sony KV-32FS12 32" TV
Sony KV-20S40 stuck on channel fix
I have just got a kv-20s43 and your best bet is to try to restore settings, here, To reset TV to factory settings, turn the TV on, Then, while pressing the reset button on the remote control, press POWER on the TV. The TV will turn itself off, then back on, the original settings wiill be restored... definition: ch. fix- 2-6: Select when you want to control all channel selection through a cable box. Select the appropriate channel(usually 3 or 4) and use the cable box's remote control for channel selection. VIDEO: select from available inputs when you have connected video equipment and you want your TV fixed to it.
Feb 01, 2010 | Sony KV-20S20 20" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Tv is stuck on channel 25
30 YR SERVICE TECH
THER ARE NUMEROUS THINGS THAT MAY HAVE CAUSED YOUR PROBLEM. TAKE IT IN TO A SONY AUTHORIZED SERVICER
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinatron has no menu control, can't auto add channels
YOU NEED TO GET INTO THE CONSUMER MENU AND ACTIVATE THE AUTO PROGRAMM MODE. I BELIEVE WALMART CARRIES A UNIVERSAL SONY REMOTE WHICH WILL ALLOW YOU INTO THE MENU.
APGONZO
30 YR SERVICER
Jan 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV
Apparently, channels have to be autoprogrammed first before those buttons will work.
Our TV is 4 years old but we never used the channel buttons bc it was always hooked up to DirecTv thru video input. SO when we disconnected the TV to sell, we thought it was a problem.
Jan 06, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Wega sony KV-36FS17
if you use your Sat remote control turn your tv on/off and there is an info button on the remote. press the tv button and then press the info button that should to it.
Oct 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony tv channel display
You need a Sony remote that has a "display" button on it. Press the display button and it will go away.
Mar 27, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Channel numbers scrolling
the tac switches have gone bad.this happens from age or sometimes from washing the screen of the set and moisture gets on the.. it is not a big job but it does involve soldering skills
Nov 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-13FS100 13" TV Logo
240 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
