DBX 100 Boombox
I have a DBX 100 boom box that has had a burn up on mains input stages, mains transformer primary is open circuit, it was switched to 110 volt operation and someone plugged into 250 volt mains in the UK without looking to adjust the input switch, there appears to be no other damage except 1 resistor burnt out, we don't know the value, so a service manual or schenatic diagram and layout is required to go any further with this repair.
Hope you can suggest an answer, many thanks.
Jim Bartlett.
email; jimbartlett@btconnect.com
The resistor may be a dropping resistor prior to a zener diode.
I'd be reluctant to try the fuse idea someone else suggested.
I also have a dbx 100 with a burnt out resistor. Can't seem to find a schematic to know what value to put back.
davidcrocombe@ozemail.com.au
Posted on Jul 15, 2009
DBX boom box burnt out risistor need advise please
I have the same problem has anyone able to help
regards
David
davidrewg@gmail.com
Posted on Aug 21, 2012
  • 1 more comment
  • Rodolf Kaado
    Rodolf Kaado Jan 11, 2013
    I used 5.6 ohms 1 watt. it works very well .
  • davidrewg
    davidrewg Jan 12, 2013
    Hi Rodold Thank you very much, was there any other parts that you needed to replace cheers?
  • davidrewg
    sorry - Rodolf not Rodold :"~
    Sergeant:
    Champion:
  • 319 Answers
I don't recommend this, but the resistor you speak of is probably a small fuse. Try jumping out the fuse, then turn on unit for brief moment. If it powers up, fine. Replace jumper wire with 1 amp fuse. If not, take to prof. tech.
Posted on Apr 17, 2008
Low disk space. Low memory. How to stop this error?
This behavior can occur if the Outbox.dbx file is corrupted.
To resolve this behavior, rename the Outbox.dbx file:
- Click Start, point to Find, and then click Files or Folders.
- In the Named box, type Outbox.dbx.
- In the Look in box, click your primary hard disk (usually drive C), and then click Find Now.
- Right-click the Outbox.dbx file that appears, and then click Rename.
- Type Outbox.old, and then click OK.
- Restart Outlook Express to rebuild the Outbox.dbx file, and then send the message.
Also you can find 100% solution www.outlookexpress.repair
Aug 30, 2017 | The Computers & Internet
I accidentally inserted a wifi dongle instead of a flash drive into the sub port of my wireless Bluetooth boombox, the Sony ZS-RS70BTB, will this break it? The dongle was reading NOT SUPPORTED.
No, because the voltage of all USBs are 5 volts. It says unsupported because your Boombox doesn't recognise a wifi dongle. I guess it is looking for music files. The wifi dongle will be fine as it won't recognise a Boombox as it is looking for a computer or television.
Jun 27, 2016 | Sony Audio Players & Recorders
Sony cfd-s01 boombox radio
Hi Bart,
You will find there is a specification plate on the rear of the unit.
It should have a rating on it showing the wattage of the unit. This is usually the amount needed to operate all the functions of the boombox.
The wattage is your input voltage multiplied by the current draw in amps. So the amperage is the rated wattage of the unit divided by the input voltage.
Usually all power goes through the transformer, so I would use this input amperage as a guide, and assuming there is no power loss, use the same calculation for the output - you know it is 9 volts, so the wattage going to the unit is the same as the input wattage, so you can calculate the amperage from this.
Transformers usually work on AC input/output, so there will also be a rectifier to convert the AC to DC for your boombox.
I would add 10 - 20% above your calculation to make sure you have sufficient power. Also I suggest that you install a fuse between your transformer and the boombox for safety.
Feb 02, 2014 | Audio Players & Recorders
How to identify the matching transformer terminal by means of terminal resistance? and which terminals is for input or output?
Doing a resistance test on a transformer will not give the information you require as you will read very little, if any resistance. What you need to do is an impedance check and that gets involved. If it is a normally wound transformer, not an auto transformer, you can isolate which is the primary and the secondary windings. Unless the transformer is a multi voltage input unit, the primary side will have continuity through only two terminals. The secondary could be more than two if it is a multi output voltage one. If the transformer is a step down, the primary windings will be the thinner wired windings and vice-versa. To actually test the transformer, get hold of a transformer with about a 20 vac output and try it across the two terminals you have identified as the primary windings, you should ge a proportional voltage of the actual output. eg. with 20 vac input and a 2 vac reading at the secondary, the actual output would be 11 vac if your mains voltage is 110 volts. Take care that you are using the transformer at the voltage it is designed for, otherwise it will overheat and burn out.
May 11, 2011 | Kitchen Ranges
The main transformer in my Sherwood amplifier is down the primary winding is open circuit. I cannot find the transformer outputs as to replace it. does any one know the voltages and current ratings for...
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Jan 25, 2010 | Audio Players & Recorders
I have a Peavy "Classic 30 BT" guitar amplifier that stopped working. When the power switch is ON, the pilot light glows but the vacuum tubes don't even glow. Using a volt meter, I found that 120 Vac is at...
Hi and welcome to FixYa,
I have to agree with you that that component is a thermal fuse. In my country, they are readily available in most electronics/hobbyist parts store. These components are also used for small motors and therefore would also be available in some (but not all) kitchen appliances parts stores. A temporary workaround is to install an ordinary fast blow fuse.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 28, 2008 | Audio Players & Recorders
DBX DriveRack PA power failure
repair the transformers,,,using a digital voltmeter when both transfrormer are good the measure like 56 ohms, if one is good and the other is bad is gonna measure like 120 ohms , if both are damage it will measure nothing, all this with the switch in its on stage.
If you dont find anyone that can repair the transformers buy them.
Jan 28, 2008 | DBX DriveRack 480 Processing Unit Home...
861 people viewed this question
 Grubhead
Grubhead
