Question about HP Photosmart C3180 All-In-One InkJet Printer
Printing a tiled document from InDesign
I have a 16x20 inch poster designed in InDesign. I check off Auto Tile but the printer will not print all the tiles. Help!
    Problem Solver:
  • 15 Answers
You have check the tile option in print dialog box and select auto justified. now the printer will print tiled documents.
Posted on Sep 16, 2009
Canon pixma iP3500
Simply crop it and print
May 23, 2013 | Office Equipment & Supplies
I have a HP designjet z2100 printer but It stop printing larger banners and now will print banners in a tile format not one contiuos document
Hello.
If the problem occurs from one computer only, remove printer from Printers and Faxes and renistall the driver.
If needed, here's the link for the driver:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=pl-89035-1&jumpid=reg_R1002_USEN
If the problem occurs from more than one computer, please let me know.
Hope this helps.
Jul 19, 2011 | HP DesignJet 5000 Printer
We are having problems printing a 10' x 42" banner on our Epson 10000 plotter. We are using a Xante Symphony RIP networked to the Plotter. For some reason it stops printing at approx. 76% (3/4) of...
STEVE you have to print it as a tiled image. there is an update on the epson website for this issue. basicly anything over 90" you have to tile as two images split in half with no border in between if that makes sense. they explain it well in the update. when its something 120" x 36" lets say i run the set up at 36 x 60 then go to the page set up and there should be a box for tie image when you preview it again it shows the tiled image put back to back. you also have to tell it toreverse the print. i use adobe cs2 illustrator and it works well.
May 28, 2011 | Epson Stylus Pro 10000 InkJet Printer
My parents have a HP P1505 and they are having trouble printing from InDesign documents. They get intermittent and funny type issues when printing straight from the document. Prints fine from a PDF. Prints...
Go to indesign. Under print options, go to output and select Greyscale instead of RGB. This takes acre of outputs from Indesign. I think the problem arises from the printer trying to interpret the colors.....
May 07, 2009 | Office Equipment & Supplies
PDF files only print in landscape
Found it! The problem was that Adobe was set to print with page scaling set to Tile. Even though you see the preview as portrait (with page setup AND printer setup also in portrait), for Tile, it prints in landscape.
User said this fixed it.
Mar 25, 2009 | Adobe Acrobat® 8.0 Standard Full Version...
Printer cutting off 5 inches from finished size from InDesign
teresa_marti,
Try to rotate from lanscape to portrait, or if plotting form Acrobat check auto rotate and denter from the properties. Since it pltted before and no resizing was don it has to be the printer preferences.
randy320sgi
Jan 07, 2009 | Adobe InDesign
I can't print full bleed from CS3 to a Phaser 7750DN
You didn't mention paper size, so my apologies if you are using a sheet that will accommodate bleeds and just didn't mention it. This is the simple answer.
If you printing on 8.5 x 11 paper, you can't get a full bleed. You'll need to print on a larger paper size, like tabloid, and trim your 8.5 x 11 size out of that. There are no printers, even commercial offset printers, that can bleed an 8.5 x 11 design on an 8.5 x 11 sheet. There must be trim in order to get the bleed. it 'bleeds' off the edges of the design.
Nov 11, 2008 | Xerox Phaser 7750DN Laser Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
Duplex printing problem
you will need to make sure that the printer software is set to align top-top or top-bottom. You will need to set this within the printer dialog set up.
Jun 14, 2007 | Adobe InDesign CS2 for Mac
HP Photosmart C3180 All-In-One InkJet Printer Logo
104 people viewed this question
Ben Johnson
