Question about Canon DR-2050C Path-Through Scanner
Canon DR-2050C software will not load
I bought a new Canon DR-2050C high speed document scanner as I was told it was compatible with Windows Vista. The package insert states it is compatible with Windows Vista both 32 and 64 bit editions. It states "follow the installation procedure in the manual provided to install the software. When doing the installation, substitute the user terminology and folder names that are appropriate for your operating system." I have tried several times to install the software via the autorun and the separate setup application that is on the CD. Each time the installation stalls after selecting the "typical or custom installation". I have tried both options, and it continues to stall on the screen saying "Now Installing". There are no options to stop, exit or continue so I can only get out of this by using task manager and ending the program. I have let the program run for hours and the hard disk indicator shows no activity after the first few min. I am using Windows Vista 32 bit edition on my Gateway NX860XL laptop. I have not yet attempted to connect the scanner to my laptop as the instructions state that you must install the software first.
  • TheBroker Sep 05, 2008
    We are having the same problem but our operating system is Window XP
  • Anonymous Feb 12, 2009
    says i need the versions before the only versions i can find.
  • 3 Answers
Everthing work except no picuture
Posted on Aug 01, 2009
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam shyam.lal@teamcomputers.com 9210845186
Sep 13, 2011 | Canon DR-2050C Path-Through Scanner
Installed driver twice for Canon DR-2050c. Still
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Sep 09, 2009 | Canon DR-2580C Path-Through Scanner
Dr-2050c multi-page document stops scanning after one or a few pages, inconsistently. Feed lever is down in the multi-page position. Feeder tries to separate the pages: sometimes it succeeds. Document...
If the scanner is scanning but stops after a few pages either it could be because of a) There is insufficient disk space (you need to delete unwanted files or direct the comp to store whre there is space) or b) the rubber rollers are not able to separate pages and feed the papers for scanning.(You need to change the rollers)
Jun 08, 2009 | Canon DR-2050C Path-Through Scanner
No Device Found?
Ive had this problem as well, and usually restarting the computer fixes the issue. im guessing that you have already tried that, but just incase ill suggest it. You can also go into device manager and remove it, and then use the software disk, reinstall.
Feb 07, 2009 | Canon DR-2050C Path-Through Scanner
Canon dr 2050c
i want the driver for canon dr-2050c
Aug 14, 2008 | Canon DR-2050C Path-Through Scanner
DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
Jul 05, 2008 | Canon DR-2050C Path-Through Scanner
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
Canon 2050C scanner
In the software, select 'multipage' option. (Check this box). The output will be collated and provided to you as a single file.
S. Mohan
Feb 08, 2007 | Canon DR-2050C Path-Through Scanner
Canon DR-2050C Path-Through Scanner Logo
297 people viewed this question
old marine
old marine
