Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Bissle will not let water out if Bladder
Our Carpet cleaner Bissell powersteamer will not release the solution to shampoo the cerpet. What is the problem ?
  • speeedman Oct 18, 2008
    this carpet cleaner is junk i go to the store and find there is another person their with the same problem. Threw it in the garbage after working on it for a couple of hours
  • 1,673 Answers
Check the vale at the bottom of the tank. Push it in and see if water comes out ok, also check to make sure the seal is on the valve asm. Check the pump belt to see if it broke. Could have a bad pump. Is the top cover seated against the base in the back, if it is raised up, then it also raises the tank so it can't work.
Posted on Apr 15, 2008
Using the bissell proheat upright carpet cleaner and no shampoo is being dispursed.
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Jul 03, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Basic how to use instructions.
1. Step on the handle releae pedal and lay the handle back.
2. Remove the tank and take it to thesink.
3. Remove the top cover cover and fill the plastic bladder with water only.
4. Replace the tank.
5. Your 'Smart Mix' (shampoo) bottle is on the operator's right in front of the machine. Remove it and fill it with Bissell shampoo.
6. Shampoo is automatically mixed with the water as you dispense it depending on how your 'Smart Mix' Knob is adjusted.
You can download your complete maual here:
May 20, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissel shampooer
yes there is a belt on the side that will need to be changed
Jan 13, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Powersteamer Pro Deluxe
could be a few things.. take the lid off the tank and try spray.
did you fill the bladder and not the outer tank.. rubber on bottom of tank still there.. releases fluid it you depress the x shape center..
hot water. prime from hose without a tool on it by holding the hose lower than the tank.. put in on a work bench.. hold spray trigger and turn on machine.... read my other posts as well
Oct 23, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Power Pro Bissell cleaner
Try going a diferent direction. Burber carpet is extreamly hard to clean because the nap it causes vacuums to bounce and shampooers to catch. just try using a differnt angle to shampoo the carpet from.
Oct 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissle carpet cleaner
Yeah....I did all that too....nothing!!! I called to have mine repaired. They said it sonds like a clogged heatercord?? I tired to look up what that was...can't find anything about it!!! ERRRRR!!!
Aug 07, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Powersteamer powerbrush
Brand new out of the box and the bucket didnt fit flush and the shampoo or water not spraying?
Mine was the same lift up the bucket and look at the rubber washer / seal take it off turn it inside out and put it back on.
Wahoo the busket fits the was washes , you have your carpet cleaner back
Jun 26, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Bissell ClearView powersteamer carpet cleaner does not seem to be dispensing water in the pre-treat mode
Pretreating (optional)
Note: Pretreating is recommended to improve
cleaning effectiveness for heavily soiled carpet in
high traffic areas such as entryways and hallways.
Spray the BISSELL Tough Stain Pre-treat formula
onto heavy traffic areas, soiled areas, or stains.
B. Allow to penetrate for at least 3 minutes.
Maybe isn't su[pposed to dispense water, just the Pre-Treat solution. Then after a few minutes, shampoo normally.
Mar 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
How to use bissell carpet cleaner
On the 1698 modle thier is a large clean water tank and a smaller shampoo bottle which seats on the side of the machine.
the shampoo goes in the smaller bottle fo the two.
Jan 02, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Soap dispenser
Probably plugged with soap. Try to clean the hole under the shampoo dispenser. Put plain water in the dispenser and hope it gradually cleans it out.
Jun 14, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
173 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
