Question about Broan-NuTone Allure II QS230SS Kitchen Hood
Does not take up the smoke or steam - 2nd unit
I had an electrician install a qs230bb hood. The rattle and vibration was so bad the glasses in my cabinets across the room rattled and the hood lights shook. The electrician tried everything but could not eliminate the problem. Customer support said it could be the blower unit is out of balance and suggested I contact the place of purchase and get a replacement hood. I had to pay an electrician again to come back to take the original one out and install the new one to an additional cost. costing me over the amount paid for the hood, over $220). The new hood was installed and a lot better noise and vibration wise, but when I fry or boil water on my front burners, the steam goes into my face and up the front of the hood into the bulb area. When I try to boil water or cook on the back burner right under the blower unit on the left side, even on 3rd speed the steam does not get sucked up, it goes all over my tiles behind my stove. This is very frustrating. I thought this was a reliable unit and company from all my research and all it has done is become a glorified $450 light (incl 2 installations and purchase).
  • DIYalways Dec 22, 2008
    We installed this hood today, without ducting, following the instructions, particularly 1-10 under "Prepare the Hood". The air exhausts out of the vents on top of the hood just fine, but there is no suction drawing the steam up at the filter, even directly below the fan motor. We've tested with a 1" piece of paper and even 1/2 inch from the filter, it does not get drawn up! The solution said to make sure the vent cover is removed. What vent cover? There's no reference to a "vent cover" in the manual that we can see. Assitance would be greatly appreciated!
  • 38 Answers
It really depends on the exit. If the duct exit has to travel really far before exiting it tends to not have as much suction. And like solution 1 said. Make sure the plate was removed
Posted on Jun 13, 2008
Check and see if vent plate was removed so fan can exhaust air
Posted on Apr 16, 2008
2006 jeep Cherokee 5.4 hemi smokes real bad and idles rough but not when revving the engine
Have you had the engine control unit scanned for fault codes? Is this oil smoke or fuel?
Oct 20, 2016 | Jeep Cherokee Cars & Trucks
In the rain driving home smoke started coming out of the hood right before that my light stopped working
Could be water got to the bulb, caused steam and blew the bulb. Pull the bulb, if the glass is broken, that's what happened.
Aug 29, 2016 | Cars & Trucks
Top refrigerator rattling inside the refrigerator when first starts to run then stops rattling
There is something loose, when first starting the compressor because of its initial load vibrates shakes etc then settles down as the system stabilizes. Move things around inside and see if this helps. If not remove everything and try again, if the rattle is still there it is part of the cabinet, if not it was something inside.
Jan 31, 2016 | Kenmore Refrigerators
Why do i get rattle from beldray electric fire ?
A rattle from an electrical appliance indicates a loose electrical component The vibration is caused by the cycles of the power in use. (hum from a fluro light) have an accredited electrician check it out as it may be serious.
Nov 17, 2014 | Cars & Trucks
2003 jeep grande cherokee white smoke from drivers side of hood
old post
smoke or steam.?
smoke lingers long, steam goes away fast
steam smells like antifreeze, sweet and nasty
smoke smells like, well, oil burning,
take eng. dip stick drip one drop of oil on a hot manifold
smell smoke, now.
Feb 20, 2014 | 2003 Jeep Grand Cherokee
White smoke comes from hood of 89 ford pick up
White smoke is actually steam, get the cooling system pressure tested. There is an outside chance that the steam is gasoline vapor so get this checked right away
Feb 03, 2014 | 1989 Ford F 150
After changing thermosat car is now smoking a lillte from the driver side radiator area
Smoking where.? tail pipe end.?
over heats, when, moving at 60mph
or only stopped.?
if that smoke is during a hot running motor, and is steam
the head gasket blew (or worse)
oil smoke burnt lingers a long time, steam goes away fast like tea pot.
smoke smells like burned oil, steam smells disgusting sweet due to
the coolant is 1/2 Glycol.
over heating has many reasons.
only stopped?, bad rad, bad pump, bad stat, bad fan clutch.(or elect fan)
fails to over heat moving, usually is bad fan (action)
steam at tail is coolant burning.
Mar 21, 2013 | 1992 Geo Storm
Rattle/vibration in the horn of my 4x10 cabinet
Open cabinet and look for loose wiring. You may have blown the tweeter horn if nothing is loose.
Aug 25, 2011 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
JRX125...there was a rattle/noise that indicated blown driver on midrange horn...replaced drivers, noise still occurs. discovered loose 1/4 in jack to tip of plug...tightened fit, but didn't trust...
The noise MIGHT be a resonance in the cabinet. The way to find out is to sweep a frequency upward to see if something rattles at certain frequencies... Don't be surprised to find several. Within the cabinet are the usual culprits: Wires rattling against the cabinet, loose debris, grilles and the logos on them, circuit boards with crossover hardware, cabinet wood that is not glued and rattles against itself. Things like bass port tubes can rattle.
Find an audio generator and sweep the cabinet from 50Hz to 10KHz and you will be surprised. Some speakers may have resonances as well. Expect things in your room to start rattling as well.
This is really the only way to find the problem. PLEASE wear hearing protectors at levels above 90Db.
Mar 27, 2011 | JBL New Jbl Jrx 125 Dbl 15 2 Way Speaker...
I've got a Behringer Ultrabass Bb410 1200w 4x10 Bass Cabinet in which 2 of the speakers rattle. I know the speakers have been removed and rewired. How can I get an internal wiring diagram to check...
The cabinet is listed as a 4 ohm unit.
We would exoect to see four, 4 ohm speakers in series parallel or four 16 ohm speakers in parallel.
If teh unit seems to rattle, first put an audio oscillator into it and sweep the frequency. It is common for grilles and also logos attached to them to rattle.
Open the unit and power each speaker the same way individually for a test.
I suspect you will find either the grille or mounting hardware is actually doing the rattling OR possibly the wires inside are vibrating.
If the sound is a scratchy buzz, then the speaker(s) have probably had voicecoils damaged by overheating.
In this case, buy 4 new speakers and replace all. It is not likely to find replacements for the Buggera brand they put in these cabinets. Also the word on the web about that brand of speaker is not very good.
Sep 21, 2010 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
Broan-NuTone Allure II QS230SS Kitchen Hood Logo
425 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
